Aisin Hubs
Old Jan 20, 2007 | 10:55 AM
olharleyman's Avatar
Aisin Hubs
I Was Just Installing A Set Of Aisin Hubs On My 90 4runner With Add And Was Going By The Install Tread That Was Forwarded To Me About The Install And All Was Going Well Untill I Tryed To See If They Were Installed Correctily. According To The Tread It States That Once Installed I Should Put Them In Lock And Raise One Side And Spin The Wheel And Check To See If The Driveline Spins Well Driveline Is Not Spinning But The Axel Spins Then When I Go To Unlock The Axel Stops Spinning Can Someone Please Tell Me If There Was A Miss Print Or If The Driveline Should Spin Not Just The Axel?
Thanks For Any Help
Old Jan 20, 2007 | 11:06 AM
Kyle95sr5's Avatar
man that paragraph is trippin me out
https://www.yotatech.com/~corey/tech...etal22lica.htm
here is an quote from that writeup "To check for proper disengagement, dial the lifted wheel to FREE and spin the lifted wheel. If the driveline does not turn and no ratcheting sound is heard, the hub is disengaging properly.
Repeat these steps for the right wheel and hub. "
I think you have them installed right, just read some really retarded instructions
Old Jan 20, 2007 | 11:09 AM
waskillywabbit's Avatar
If you "lock" just the hubs the axle will spin as that "locks" the hub to the axle. For the FRONT driveshaft to spin you have to put the vehicle in 4WD.
Old Jan 20, 2007 | 11:32 AM
So Sounds Like They May Be Installed Correctily The?? When I Go To Free The Axel Wont Spin But In Lock They Do Spin Sound Right?? Just For The Record That Is The Yhread I Used But If You Read It Again It Says Nothing About Being In 4wd To Test But I Have Faith In Waskillywabbit And Illtry To Put It 4wd And See What Happens
Thank For The Help Fellias
Old Jan 20, 2007 | 11:55 AM
Well Im Not Sure If They Worked Or Not Still Cant Get Driveline To Spin With One On Ground And One In Air IN 4WD LIGHT COMES ON ON DASH SHOWING 4WD Go Figure
Old Jan 20, 2007 | 12:29 PM
RustBucket's Avatar
If you take a few pics of the install people here might be able to help you out. Did you make sure to put in the inner hub bolt? It's a little 12mm thing you have to torque down with a hammer.
Basically if you jack up a wheel, when the hubs are unlocked you should be able to turn the wheel freely and the CV axle should not spin at all. When the hubs are locked, the CV should turn with the wheel.
Old Jan 20, 2007 | 12:36 PM
Kyle95sr5's Avatar
Well you said when they are unlocked, the cvs dont spin and when they are locked, the cvs spin. That is exactly what your trying to get at.
Old Jan 20, 2007 | 04:05 PM
curly_c's Avatar
Why All The Capital Letters???? its driving me crazy reading your posts like that. Axel spin is what you are looking for. in lock it should spin, which it does, in free it shouldnt. there ya go. thats how mine work.
Old Jan 20, 2007 | 04:07 PM
DeathCougar's Avatar
You Have Got To Stop Typing Like This. Its Is Very Hard To Read.
Since you have ADD, the driveline will not spin unless its in 4wd.
Old Jan 20, 2007 | 04:17 PM
RustBucket's Avatar
Just an idea... if you have shifted it into 4WD, I imagine the engine has to be on since ADD is operated by vacuum.
Old Jan 20, 2007 | 07:43 PM
ok sorry about the caps had cap lock on and did not notice. ya i guess that ill have to put the rear on jack stands and floor jack the front and start the motor and see what happens.by the way rustbucket im very happy to say you sold me a very nice set of hubs.
Old Jan 21, 2007 | 04:21 AM
woodworth's Avatar
to much work
just installed mine, and man your over thinking this. with all 4 wheels on the ground, put hubs in free, reach behind the front wheel, grab the cv (axle w/ boot on both ends) and turn it. if it turns freely you installed them right.
when driving first thing i noticed was a speck easyer to turn the steering wheel and i coasted a lot further when i took my foot off the gas.
hope this helps
Woody
ladybugRC
458
Aug 21, 2020 10:41 AM
G-off
Dec 29, 2015 12:44 PM
Toys4parts
Sep 26, 2015 01:56 PM
mxdw88
Sep 20, 2015 03:13 AM
