Aisin Hub Problem
Old Mar 16, 2008 | 05:06 PM
jdcarnathan's Avatar
Aisin Hub Problem
Regreased my manual hub today and I am pretty sure all the springs are right and everything. I have looked at the posts on here and read but is there any other reason why it wont engage the cv axel. thanks i figure it is just the spring is not quite right but would like a second opinion
Old Mar 16, 2008 | 05:24 PM
89silverpu's Avatar
I just did this yesterday too, you probably have too much grease in it for it to be able to slide in and out easily, I had the same problem
Old Mar 16, 2008 | 05:27 PM
Dublin's Avatar
X2 on over grease, had the same problem 1st time around.
Old Mar 16, 2008 | 05:46 PM
ok I will try that tomorrow. that is weird over greasing it. who knew.
Old Mar 16, 2008 | 06:09 PM
waskillywabbit's Avatar
A slight coating on everything is all that is needed otherwise it gets suction and sticks in/out.
Also make sure you did not put the big spring in upside down. The flat part sits on the pawl NOT the hub dial/face.
Brenjen's Avatar
Me, but then again I've been playing around in the guts of other brands of manual hubs for years. Wait until you think you got it whipped & then you try to engage them in below freezing temps. I used to thin my grease with WD-40 so it was a little more fluid back in the day but I learned to just lightly grease them & all is well.
Old Mar 16, 2008 | 11:26 PM
Matt16's Avatar
Make sure you put the hub dial in set to specifically FREE or LOCK, I can't remember which, but it makes a difference. Read the writeup carefully.
Old Mar 17, 2008 | 12:28 PM
leebee's Avatar
you want it in 'free' position to dis-assemble, otherwise, youll be chasing springs!
lee
Old Mar 17, 2008 | 01:10 PM
Matt16's Avatar
There you go.
Old Mar 17, 2008 | 05:02 PM
Brenjen's Avatar
The setting just has to match the dial, there is only one large spring to deal with as long as you don't take the face of the dial off to expose the second small spring with the tiny ball bearing. It's painfully simple to do really & even if you had never seen one before you could figure out how it went back together by looking at it.
Old Mar 17, 2008 | 07:10 PM
took it apart and wiped some of the grease out of it. now it works like a champ. thanks guys didnt think about the suction at all.
Old Mar 18, 2008 | 05:23 PM
89silverpu's Avatar
no problem thats what we're here for!
oldirtydirt
Feb 23, 2020 09:30 AM
MTLroadierunner
Jul 20, 2015 03:07 PM
PlayAwhile
Jul 20, 2015 11:36 AM
1996Taco
Jul 20, 2015 12:02 AM
Steven.m.paulk
Jul 13, 2015 01:40 PM
