Aftermarket Oil Pressure Guage Install ?
Old Mar 31, 2007 | 03:05 PM
brendonv's Avatar
I want to install an aftermarket (Auto Meter), oil pressure guage on my 22re. I did some searching but didn't find any definate info. Is there an available hole (other than the stock oil pressure sender), where I can use to mount this guage from? I did some reading that said there is a port behind pass. side motor mount, is this true, and are there any others?
Old Mar 31, 2007 | 03:29 PM
89 toy's Avatar
there is a port behind the passenger motor mount it has a plug screwed in it. i put mine where the stock sender was and put the stock one in the other hole because i was woried about the plastic hose geting a hole rubbed in it from the motor mount.
Old Mar 31, 2007 | 04:00 PM
operose's Avatar
I put my mechanical (sunpro) gauge in the stock sender location.
If you are worried about the plastic tubing getting a hole in it, you can buy one of these http://www.tooldiscounter.com/ItemDi...e&kw=SNPCP8212
it is an electric gauge with a sender that mounts on the engine so you only need to run a wire into the cab.
Old Mar 31, 2007 | 05:57 PM
brendonv's Avatar
Cool thanks.
Thats what I needed to know.
Old Oct 17, 2007 | 04:45 AM
scrid's Avatar
oil sender
I just ordered one of these indiglo oil pressure guage kits.
Anyone know offhand there is an unused oil port on the 3VZE I can use so I don't have to remove the stock sender?
Thanks
Old Oct 17, 2007 | 05:27 AM
NCSU-4runner's Avatar
I'd prefer an electronic gauge for things like oil and fuel pressure where a hole in the line could spell trouble. They cost more but I think its worth it.
Old Oct 21, 2007 | 04:10 PM
scrid's Avatar
oil pressure sender
Can anyone verify that the sender threads in the oil gally are 1/8" pipe?
Thanks.
Old Oct 21, 2007 | 04:15 PM
n4ynu1010's Avatar
Thanks.
Pretty sure they are standard but get some more input on that and Autometer makes a nice gauge , have used them for years
Old Nov 3, 2007 | 08:48 PM
T4R 4ME's Avatar
Am I missing a write up somewhere on here for this or any other gauges? I don't see any. I'm thinking about doing this and want an idea of what I'm getting into.
Thanks!!!
Old Nov 4, 2007 | 02:46 AM
TORTIS's Avatar
i recall reading, where you had to get a special T if you were going to run both out of the same hole
Old Nov 4, 2007 | 01:42 PM
T4R 4ME's Avatar
Guess I didn't look hard enough. Found some good info here
Old Nov 4, 2007 | 02:25 PM
toyotatom93's Avatar
Hey nice gauge link there
Old Jan 25, 2012 | 03:03 PM
pholife's Avatar
has anybody put aftermarket electric oil pressure in 3vze 3.0 with still maintaining the stock oil pressure gauge in the cluster too? thank you
Old Mar 24, 2012 | 10:12 AM
93liftedyoda's Avatar
Where is the stock oil sending unit located at?
Old Mar 24, 2012 | 10:55 AM
Bassmastry101's Avatar
Above the oil filter.
I just did away with my stock gauge and ran a hard line. More accurate that an electric gauge and there was no need for two oil pressure gauges.
Old Mar 26, 2012 | 11:18 PM
weaselman's Avatar
thread is hella old, but i ran a t fitting and screwed both my stock sender and aftermarket gauge into it, both worked fine and read proper pressures.... and the threads in a 22re are 1/8 BSPT not 1/8 standard.
Old Mar 27, 2012 | 12:02 AM
wyoming9's Avatar
Red face
Interesting on my block the stock oil pressure threads are metric I can`t remember just what size.
I have run a mechanical gauge for years with no issues I ran copper tubing inside of rubber hose I have had no problems.
With a mechanical gauge just remember to bleed the line.:jessica:
Old Mar 28, 2012 | 11:36 AM
weaselman's Avatar
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Sep 4, 2015 09:27 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
HRDC0R19
Jul 5, 2015 06:43 PM
