After locker install and wheeling I have a new vibration
Old Mar 7, 2010 | 03:43 PM
Junkers88's Avatar
Alright folks, I'm going to need some help with this one.
I recently dropped in a front locker for the rig and have been slowly learning what a double locked rig can and cannot do. (89 4runner, 22re, 5 speed, Aussie in the rear, Lockrite in the front, 4.56's and 31's but most of ya'll knew that from my posts over the last year).
Went wheeling the day I put the locker in and things were freaking awesome. I did notice a slight vibration on the way home that only happens when I'm holding the throttle to maintain speed. Example: I'm doing 70 on the highway and holding at 70 it will vibrate enough to "feel" it in the truck. If I accelerate or let off the pedal it goes away.
That wheeling trip was almost 90% mud with a few minor rock crawls, as I said I'm trying to learn the rigs capabilities with the front locked, and I did my best to wash all the mud off of the drive train when I was done.
So far I have no strange steering issues, no wheel hop or tracking issues, fluid levels in the motor/tranny/tcase/diffs are where they should be. Now if I'm on the street and can feel the vibration I can clutch the rig or just pull it out of gear and the vibration is gone.
I'm hoping this is something as simple as a loose nut (not the one in the drivers seat thank you) or something similar.
Help?
edit: Having two lockers makes this thing a blast to wheel.... I mean that.
Old Mar 7, 2010 | 03:50 PM
diablo's Avatar
Didyou mark the drive shaft before you pulled it off so its on the same as before the install, just thought i would ask. I had to turn mine till I found where it vibrated the least.
Old Mar 7, 2010 | 03:55 PM
BigBluePile's Avatar
So you think it's some thing in the back vibrating or the front?
It's PROBABLY the nut behind the wheel...I'm just sayin...
Old Mar 7, 2010 | 03:56 PM
shaeff's Avatar
Check your U-joints.
Old Mar 7, 2010 | 04:30 PM
Junkers88's Avatar
The locker was installed in the front and I don't run the front on the street so I can't see how that would cause a vibration.
It has got to be in the back. The front isn't running unless I'm on the trail.
Oh and SHUSH!.
I have not yet although I can't see them going out after one wheeling trip unless the front being locked would have caused some strain on the rear.
Old Mar 7, 2010 | 04:33 PM
survivorman97's Avatar
Does your drive shaft have a carrier bearing with a rubber boot? Sometimes those get to much flop in them....
Old Mar 7, 2010 | 04:34 PM
Does your drive shaft have a carrier bearing? Sometimes the boot in those gets too much slop in them...
Old Mar 7, 2010 | 04:49 PM
Check your drive shaft or your wheel wieghts?
Old Mar 7, 2010 | 05:08 PM
Junkers88's Avatar
No carrier bearing but thanks for the thought.
Wheel weights? Would a loss of one or two cause this??
Old Mar 7, 2010 | 05:13 PM
Would hurt to check, might just start wiggling at just the right speed as opposed to all the time.
Old Mar 7, 2010 | 11:51 PM
nytro88t4r's Avatar
i say u-joint also, my runner was doin the same thing, had a busted rear
Old Mar 8, 2010 | 12:14 AM
g_cali's Avatar
My vote is u-joint also, because my truck is currently sitting in the driveway with a broken rear u-joint...
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
rushw
Jul 18, 2015 01:46 PM
A2theK
Jul 12, 2015 10:46 AM
