Advice on Detroit True Trac or Lockrite in front diff?
Old Jan 20, 2013 | 12:07 PM
Evrgrnmtnman's Avatar
So, recently I busted a inner axle shaft in my front diff on the passenger side of my 88 Pickup which has a Detroit True Trac inside it. I picked up another front diff on Craigslist with a Lockrite locker inside it. So, do I switch out the Lockrite Locker in this one with the Detroit True Trac which is in my current broken diff?? This is more of a every day driver, and I live in the mountains of Colorado where we get snow in the winter???
Which one is better? Thoughts, opinions, advice
Thanks..........
Old Jan 20, 2013 | 03:09 PM
BeMiceElf's Avatar
For the conditions you are describing, I would stick with the true-trac.
Old Jan 20, 2013 | 03:38 PM
aztoyman's Avatar
My 88 had Tru-Tracs in both axles when I bought it. Great for the street, sand and snow. Sucked on the rocks.
Running Aussies in both axles now, great on the rocks, sucks on the street and in snow.
For how you will be using it, I'd stick with the Tru-Trac like BeMiceElf said.
Old Jan 20, 2013 | 03:39 PM
vital22re's Avatar
totally a bro
I like my trutrac in the snow. It tracks straight with only slightly heavier steering feel.
Old Jan 20, 2013 | 06:43 PM
JasperOffroad's Avatar
Lock-rite up front in the snow will be absolutely terrible.
Old Jan 20, 2013 | 08:58 PM
TrikeKid's Avatar
If you enjoy being able to steer on the street in snow/ice, keep your true-trac.
Old Jan 21, 2013 | 06:22 AM
Dave the welder's Avatar
I had bad luck with "lunch box" lockers. I have a tru track in my sfa and its ok on the trail and good on the street/snow.
Old Jan 21, 2013 | 07:07 AM
250000_yota's Avatar
True trac. I have one in the rear of my truck, and aside from a selectable in front, that would be my next choice for a street driven front. My rear true trac is vey forgiving. Not the best for offroad but definitely my choice for a street driven 4x4. If all you did was break a stub axle, the swap the axle and long side tube if on the drivers side...
Old Jan 21, 2013 | 11:58 AM
Well, sounds like True Trac is the way to go......Broke the stub on the passenger side, so maybe just replace that one with the diff I bought on Craigslist..
Old Jan 21, 2013 | 05:36 PM
Laurentian's Avatar
I had a True Trac in my '86 IFS and loved it. For icy roads / snow it was awesome. I am buldng up a '95 same way.
If you change your mind on keeping the true-trac I would like first dibs on it no matter the ratio.
Regards,
Hugh
Old Jan 22, 2013 | 05:16 AM
johnboy68's Avatar
As everyone else said and for the same reasons, stick with the True Track.
Old Jan 22, 2013 | 11:28 AM
Will do! Thanks for the input.........
88sasturbotoy
Jan 30, 2026 01:57 PM
oldirtydirt
Feb 23, 2020 09:30 AM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
TokyoD23
Jul 12, 2015 06:01 AM
