adjusted TPS, now erratic idle.
Old 09-29-2010, 06:15 PM
  #41
DupermanDave's Avatar
When the TPS is unplugged, the idle does not rise when I hold down the brakes for 30+ seconds like it typically does at a stoplight.
Anyone have any ideas as to what's going on? Is the TPS bad? I was doing some research on symptoms of a bad TPS, and I don't see any of the typical signs. Just the rising idle.
So here's the facts:
-The TPS was fine before I started messing with it. I may have had a small stumble on takeoff, so I decided to adjust the TPS. There was no floppy idle, no rising idle, no vacuum leak and no bad throttle body or TPS.
-It's not a timing issue, because I tried adjusting the timing by ear and I also eventually pulled out the timing light to set the timing 5 degrees BTDC
-the engine runs fine with the TPS unplugged.
-there's no vacuum leaks or bad gaskets. If there was a vacuum leak, unplugging the TPS wouldnt affect the climbing idle.
-edit-
I was messing around with some hoses and I noticed if I removed the PCV valve the idle would drop a bit but it would at least be stable and not rise. Could this be a hint?
-edit-
for anyone needing an answer, I think I fixed the issue. I took off the throttle body again (leaving coolant hoses attached) and removed the old RTV gasket and replaced it with a very very thin layer of RTV, my cheese-it box gasket, and another thin thin layer of copper RTV. The idle is stable now and does not climb when sitting at a stop light.
On a side note, I filled the tank with 50/50 e85 and 87 octane and it runs fine :-)
Old 12-23-2010, 07:30 PM
  #42
thedude134's Avatar
Beauty
Originally Posted by thook
BTW, the TPS is merely a switch. Where the IDL circuit is concerned, it is just like a light switch. With a light switch, you have wires to the switch, then the switch, then the wires to the light fixture. If you're light bulb is flickering, you have to track down the problem within the circuit. Check the power supply. Say it's fine. You're getting 120v's from the breaker. Then, test the wires coming from the breaker where they connect to the switch terminals. Let's say all good. You're getting 120v's at the hot terminal. Now, test the output side of the switch. That would be the terminals where the wires going to the fixture would connected. Oops.....you're only getting 4v's intermittently. Somethings wrong with the switch. So, you're light's flickering. Something making poor contact.
Okay. With your sensor the IDL circuit is this switch. You can test for voltage, but the amount of resistance will suffice because it will tell you if the supplied voltage will even pass through the circuit properly.
With the light switch example, resistance should be zero as you don't want anything to compromise or impede the 120v's you need to be getting. The zero would indicate a closed circuit, meaning voltage can pass through. The light will turn on. If it read infinite, it would mean the circuit is broken, no contact between wiring and/or terminals is being made and voltage cannot pass. The light switch being turned off is a prime example. Contacts/circuit is broken. Light is off. Any amount of resistance value other than zero or infinite would mean there's damage to the wiring or terminal and the amount of voltage will be less than what's needed.
So back to the sensor, when the IDL switch is "on", or in range for a voltage signal to be relayed back to the ECU, it should read within the proper resistance indicating that the circuit is complete and the amount of voltage being relayed will also fall within spec/what the ECU is needing. Once the throttle plate opens, the IDL circuit/contact should break and indicate infinite. No voltage can pass. This means, to the ECU, the light is "off". Or, idle is off and throttle is open........which is where your VTA (throttle valve angle) becomes relevant.
So, when adjusting/setting the TPS, the resistance needs to be below 2.3k so that the ECU will receive a static reading of voltage (no more or less than what is needs....and, I forget how much it does need) indicating the engine/throttle is at idle. If the voltage is steady, the idle should be steady.........of course, provided nothing is wrong with anything else on the engine.
Anyway, hope that clarifies the subject for you a bit. If not, sorry. But, I try... If you have anymore questions, ask.
Superb explanation if you ask me. This explanation helped on so many other tangents to which i can apply to the other sensors and other elec crap my rig has. thanks!
Longbed 90
03-11-2019 12:38 PM
bhaithc
09-17-2015 07:53 PM
Anthony Lee Mathis
09-15-2015 07:22 AM
jacked_72
09-14-2015 03:31 PM
moparbay
09-03-2015 12:48 PM
Quick Reply: adjusted TPS, now erratic idle.
