Adding Cruise Control ?.
Old Jul 17, 2010 | 11:16 PM
myyota's Avatar
My 86 4Runner doesn`t have cruise control, but i would like to add it if possible, are the electrical connections that are needed already there under the dash ?, my 4Runner isn`t here or i would go and look instead of asking here.
Old Jul 18, 2010 | 01:27 PM
myyota's Avatar
Anyone ???.
Old Jul 18, 2010 | 01:50 PM
Fink's Avatar
Have you tried searching?
There are a few threads on this but I can't remember which years/engines.
Fink
Old Jul 18, 2010 | 02:32 PM
myyota's Avatar
I did search, but couldn`t find any information on adding cruise control.
Old Jul 18, 2010 | 02:34 PM
Fink's Avatar
I searched using "adding cruise control" and found these...
https://www.yotatech.com/forums/f116...cruise+control
I have not read them but I bet there is some info in there that could help you.
Fink
Old Jul 18, 2010 | 04:30 PM
myyota's Avatar
Fink
When i did my search i did actually read those two links, but there is no information on adding cruise control to a vehicle that doesn`t have it. Such as wiring or whats needed to hook it up.
Old Jul 19, 2010 | 06:35 AM
Fink's Avatar
Well hopefully somebody will chime in - I could have sworn there was a thread on here about it.
Knowing my memory though, that was like 5 years ago or it never actually existed.
Fink
Old Jul 19, 2010 | 07:11 AM
hilandfrog's Avatar
This is info from adding an AC but IIRC the adding CC thread said similar things....
The plugs and wires are in the trucks main wire loom, the controller part, on/off, set, resume , coast, excell, either on the wheel on the little "turn signal" type will need to be added.
From looking under my hood....
There is a an extra throttle wire and thus a different throttle cable to throttle body attachment bracket.
One will need a CC VSV and a few feet of vacuum line.
The main CC computer control brain is under the drivers side kick panel and on mine at least, it appears to be an easy ADD to a car w/ out CC.
I would attempt to get the same year donor parts, as w/ my AC the plugs had changed 1/2 way through 1994.... the AC has an 8 pin and the truck a 10 pin....
I have some soldering to do:cry
Repo
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
aowRS
Sep 13, 2017 08:22 AM
JRB4Runner2015
Sep 20, 2015 12:29 AM
sonorn67
Sep 19, 2015 05:39 PM
87SR5justin
Sep 15, 2015 06:48 PM
