ADD vacuum question
Old Nov 11, 2015 | 04:10 AM
mtrdrms's Avatar
ADD vacuum question
Hello all. I have a 93 That is not cooperating. So it has the add 4wd system and 4wd is not engaging. I have traced the problem to no vacuum from the engagement vsv. My question is, how do I test the vsv and what actuates the vsv? Is it a switch on the tcase?
Old Nov 11, 2015 | 07:28 AM
scope103's Avatar
For all questions, consult The Good Book: http://web.archive.org/web/201204242...26addcontr.pdf
There are two VSVs. Do you have vacuum TO each? The VSVs are driven by 12v; the ground side should be white-black (which you will confirm with your multimeter) and you can run 12v to the "other" side to see if the VSVs work.
Old Nov 11, 2015 | 07:46 AM
mtrdrms's Avatar
Ok tests show 12 volts to one when the 4wd lever is in 2wd and 12 volts to the other vsv when I put it in 4wd. Only problem is the 4wd vsv does not apply any vacuum to the line going to the diff when it gets 12v. Bad vsv?
Old Nov 11, 2015 | 08:46 AM
scope103's Avatar
Originally Posted by mtrdrms
... Only problem is the 4wd vsv does not apply any vacuum to the line going to the diff when it gets 12v. Bad vsv?
... Do you have vacuum TO each? ....
If you have vacuum to the VSV, and it has switched voltage, then yes, I would suspect it.
The good news is that this part is only $425 (if you get it online; more from a brick-and-mortar dealer) http://www.toyotapartsoverstock.com/...544035010.html So I would at least check the coil for continuity first (you could have a good coil but bad valve, but one thing at a time).
Running the part number I stumbled on this used part: http://www.ebay.com/itm/like/131636133994?ul_noapp=true&chn=ps&lpid=82 Since it just as old (probably older) than the one you have now, no telling how long it will last. But compared to dealer price you might think of stocking up on this part just in case!
Woodsie
Nov 18, 2015 01:20 PM
Lifted94XLT
Nov 15, 2015 03:50 PM
Yotahuntingrig93
Nov 2, 2015 11:39 PM
Lzryde
Oct 31, 2015 04:53 PM
moparbay
Oct 22, 2015 09:49 AM
