add a leaf
Old Sep 9, 2010 | 03:19 PM
  #41
greatskiiiier's Avatar
mine? yes, im 99% sure, lol how would i tell?
and ya, thats the exact math i was doing, i think something off on his, but i also just realized, we both have the older body style, he has the newer, maybe the fender is different and sits higher?
i doubt it but maybe, more than likely he just measured wrong lol
lol, i like how between you and me we have 8 posts in this thread alone in only an hour
Old Sep 9, 2010 | 03:22 PM
  #42
xxxtreme22r's Avatar
oh yeah the 92's fenders are quite different from ours. only way to tell that though for sure is get 92Toy to measure his. he's not lifted either.
Old Sep 9, 2010 | 03:27 PM
  #43
my 94 measured roughly the same as my truck now so i really think that he just measured wrong (if youd like take a look at my "post your height with x lift" thread from last year
Old Sep 9, 2010 | 03:30 PM
  #44
the only thing is it looks as though using my math your still like 3-4" lower than you should be as well. seems like your saying your at 15" when you should be at like 18-19.
Old Sep 9, 2010 | 03:32 PM
  #45
im not lifted at all, i never touched the front, only raised the rear back up to what i thought was stock (height of the front) which took the procomp AAL under the 2nd to top leaf spring and a 1" block
Old Sep 9, 2010 | 03:34 PM
  #46
oh ok thought you were trying to match his setup and had the same BJ/AAL w 3" body lift. just remember I believe the rear fenderwells are actually physically lower than the front fenderwells. ie not cut as high. by how much I don't know. I don't have a factory bed.
Old Sep 9, 2010 | 03:44 PM
  #47
lol opps? guess im rear sits alot higher than the front, but to the eye it appears level
Old Sep 9, 2010 | 03:45 PM
  #48
^^^^^ lol see noob. hahahah
it seems level because the bottoms of the fenders are. some people like them raked a little though, otherwise alot of other trucks would not have "leveling" kits.
Old Sep 9, 2010 | 03:50 PM
  #49
so people like the look of the front sitting higher? i like the rear sitting higher since its a pickup truck and thats how it should it, right now my rear is like .25 higher than the front, before the front was like 3" higher than the rear
Old Sep 9, 2010 | 03:51 PM
  #50
i think most people like the rear higher or level. the guys running a snowplow or something are gonna want the front a little higher though in order to level out the truck when the plow is put on.
Old Sep 9, 2010 | 03:54 PM
  #51
im lost then, lol, you said the rear fender well is suppose to sit lower, didnt you? lol
Old Sep 9, 2010 | 03:57 PM
  #52
technically yes. to level out the frame to factory specs the rear would "appear" lower because the bottom of the rear fender is cut smaller/lower. what I don;t know is by how much. only way to tell is to measure from a body line.
my BMW is real bad for that because the rear fender is like cut 2-3" lower so it actually looks like the car is squatting in the rear because the fender is almost level with the tire. And the front has like a 2-3" gap between the fender and the tire.
Old Sep 9, 2010 | 04:01 PM
  #53
thats funny because when i bought my 94 the rear sat and inch taller than the front and they guy said he put an AAL in it, so he must have thought the same thing, either way, 33s on a stock height compact truck is pretty cool
Old Sep 9, 2010 | 04:04 PM
  #54
yeah, but see I am not too sure if a 33X12.50 would actually fit on mine without rubbing. Possibly a 33X10.5. not a whole lot of room up front with my 31's at full stuff and full lock. could just be back spacing though. I don't know and can't afford a set of 33's right now to try it. lol
Old Sep 9, 2010 | 04:14 PM
  #55
if you're ever in or near Oswego, NY you can try my shoes on for size
I havent been off road yet or flexed at all to see how my suspension does fully compressed with the 33s but they do rub at full turn on the street as is
Old Sep 9, 2010 | 05:13 PM
  #56
BackGateYota92's Avatar
haha im confused but ya that was just me slapping the tape measure from the top of the rim to the bottom of the fender really fast. tomorrow i will for real measure. haha
Old Sep 9, 2010 | 05:16 PM
  #57
Old Sep 9, 2010 | 05:57 PM
  #58
haha exactly xxxtreme
Old Sep 10, 2010 | 05:16 AM
  #59
Old Sep 10, 2010 | 06:23 AM
  #60
just measured my (lift) again, and im pretty sure the ground wasnt level because i kept getting diff measurements for EVERYTHING and apparently all 4 corners are diff lmao, but all said and done, based on the front being 13" stock, the front of my truck is lifted 2" and the rear, based on body lines, is lifted 3-3.5"
