AC tensioner help
Old May 22, 2023 | 02:10 PM
ratherbhunting's Avatar
AC tensioner help
I can’t for the life of me figure out this tensioner on the AC. I don’t have the screw on the back of the idler pulley like I keep seeing. Can someone tell me if this is a different type of set up or what. The only bolt I thought might release tensioner is a big 18mm that won’t budge.
Old May 23, 2023 | 03:11 AM
JoeS's Avatar
My guess is the bolt on the backside of the pulley mount secures the position. The front bolt just holds the pulley to the bracket. The bracket has a 'squared' shaft that look like it is meant to take an open end wrench for leverage to tighten the belt. Then at the same time you tighten the backside bolt to hold the pulley in place.
chinook/fj55
Jan 9, 2023 12:46 PM
881stgen
May 2, 2017 07:14 AM
whitebullet3
Jun 17, 2010 07:16 AM
One_96TR4
Jun 16, 2009 07:41 PM
