ac install help
Old Apr 24, 2015 | 04:22 AM
yota_dude's Avatar
ac install help
Hey everyone
I am installing a complete ac system into my truck and I can not figure out where one of the connection goes. My truck is a 1988 pickup 22re. It's a 4 prong connector that comes off the ac amplifier. If anyone could help me by telling me where it goes or if I even need to connect it. Thanks for everyone's help.
Old Apr 24, 2015 | 06:09 AM
Terrys87's Avatar
There are two connections to the Main Harness along the top of the dash. It looks like one of those but I could be wrong. I have installed ac and have run into where everything is nearly the same but they do change one plug on them for some years. You may need to get one from the bone yard for your year.
Old Apr 24, 2015 | 01:48 PM
cabot's Avatar
The A/C harness is all hooked up in my truck, and the dash is ripped out. I'll take a picture of that tonight. I don't have a specific answer off the top of my head. Air Conditioning in general baffles me.
Old Apr 24, 2015 | 02:03 PM
yota_dude's Avatar
That would help out a ton thank you
Old Apr 24, 2015 | 04:41 PM
cabot's Avatar
Here it is all together:
Found your connector:
That other one up top has three prongs.
Old Apr 24, 2015 | 05:37 PM
yota_dude's Avatar
Is your truck a 22re or 22r? Thank you so much for the pictures
Old Apr 24, 2015 | 05:41 PM
cabot's Avatar
Mine is 1985 22RE
Old Apr 24, 2015 | 05:56 PM
yota_dude's Avatar
Thanks for the quick response mine has a different conection right there
Old Apr 24, 2015 | 06:03 PM
cabot's Avatar
Looks like you need to source a connector and do some wiring. The FSM has a wiring diagram. It changes sometimes year to year. You could look at the colors in the harness for your truck and in the harness for the year the A/C came from and compare to see which pin should go where.
Old Apr 25, 2015 | 07:03 PM
yota_dude's Avatar
Well it looks like I may have found the problem. The place I ordered the whole ac system from pulled it from a carb truck and not a fuel injected one. They are going to send the right parts out monday. So I hope all goes well. Thanks for everyones help
Old Apr 26, 2015 | 07:58 AM
Terrys87's Avatar
I did not realize car and fuel injected made a difference. I have seen some year changes on the wiring. Thanks for letting us know there is a difference. Will keep that in mind. Thanks again!!!
Old Apr 26, 2015 | 09:31 AM
cabot's Avatar
I think it's a year difference too. I don't think it is carb vs EFI. I'm EFI and have the connector in question correctly hooked up. I'm thinking it's early vs late that's the issue.
nvdesertrunner
May 11, 2020 08:18 PM
wwjr
Sep 7, 2015 09:27 AM
punks_is_4x4
Aug 21, 2015 01:35 PM
Esibnitsud
Jul 30, 2015 08:19 PM
