AC Evaporator Clogged
Old Sep 19, 2024 | 05:14 AM
Hilux 1 & 2's Avatar
1994 Toyota Pickup 4X4 with 275,000 miles, 22RE, 5 Speed Manual. Toyota trucks are the finest of machines. 5 years ago I added air conditioning since it is a factory non-AC truck. The AC has functioned decently for those 5 years. I had the AC system recharged since it had refrigerant leaking from one of the Schrader valves. Following this recharge the AC was blowing cold and the evaporator is creating a larger volume of water condensation. Recently I noticed condensation draining inside the cab onto the carpet beneath the glove box. I then got out my pancake air compressor and discharged 150 PSI air backwards up the evaporator box condensation drain pipe from outside the truck. Approximately one-half gallon of water drained from the evaporator box. Now the AC compressor clutch will not turn on at idle speed. The AC clutch does turn on just above idle speed and it still blows cold air. Blowing the water backwards into the evaporator box apparently caused some sort of setting change. Could it be the low pressure switch or its associated fuse? Could it also be the AC Amplifier itself or associated fuse busted?
Old Sep 19, 2024 | 07:13 AM
scope103's Avatar
150psi! What, you didn't have 600psi available?
Welcome to YotaTech.
Well, the A/C is "supposed" to turn off at a lower rpm (otherwise, it could stall the engine). The A/C amplifier has a control ominously labelled "rpm."
It is said that control adjusts the turn-off speed. I have a small collection of manuals for this vintage Toyota pickup, and none of those manuals make any reference to this control. You could try playing with it (and let us know your results if you do), but I will say that something that poorly documented might be the sort of thing that could break everything.
Good luck!
andyf0722
Aug 10, 2021 05:25 PM
ashamsuddin
Jun 2, 2012 02:21 PM
ReneB64
May 23, 2008 09:25 AM
toyotarunner92
Feb 28, 2008 04:15 PM
hdave_CO
Jul 27, 2005 08:52 AM
