About ignitor
Old Sep 2, 2024 | 05:56 PM
songching's Avatar
About ignitor
Hello everyone, my car occasionally idles too low and stalls when idling. The maintenance staff said it might be an abnormality in the ignition controller. When I was looking for parts, I found that there were no substitutes for my parts. My part number is 19070-35280. and 89620-35280. I only know that my car model is rn101. How can I find parts from the sub-factory?
Google Translate, please forgive me if the language is not correct, thank you.
Old Sep 2, 2024 | 06:54 PM
songching's Avatar
[/QUOTE]
Old Sep 3, 2024 | 10:17 AM
osv's Avatar
osv
it does look like your 89620-35280 igniter is out of stock, and i can't find any cross-reference part numbers from other manufacturers, you'll have to buy it used somewhere... if you were in america i'd suggest car-parts.com
i think that it's for a 1991 22re?
usually these igniters either work fine or they don't work at all.
Old Sep 3, 2024 | 11:01 AM
Jimkola's Avatar
YT Community Team
5 Year Member
Kinda doubt igniter. AFM would make more sense, though I'm reluctant to condemn that, either.
What kind of plugs? What brand cap/rotor/wire set?
Old Sep 3, 2024 | 04:01 PM
songching's Avatar
I am wondering if I can use 89620-35310 as a replacement. Since it is the same engine, can I use the 35310 ignition controller with its high voltage coil?
Old Sep 3, 2024 | 04:13 PM
songching's Avatar
My technician said it might be AFM, but he wasn't sure, so he suggested that I replace both to be safer. I already followed the YouTube video to clean it, but it had no effect.
Old Sep 3, 2024 | 04:15 PM
Discombobulated's Avatar
So are you going parts cannon on this or have you started simple first?? As stated above, have you checked the plugs, wires, cap and rotor? I don’t see many threads that the ignitor is bad…
lots of things can make your idle low but I would not start with the ignitor……
Old Sep 3, 2024 | 07:39 PM
songching's Avatar
My distributor has been inspected and the spark plug and all the vacuum tubes have been replaced. I don’t know where to find them. Do you have any suggestions?
Old Sep 4, 2024 | 06:55 AM
Jimkola's Avatar
YT Community Team
5 Year Member
Does this occur anytime the vehicle is running, or only when first started cold?
You seriously need a new technician.
Old Sep 4, 2024 | 07:32 AM
osv's Avatar
osv
my guess is no, but you should do a search because that question has been asked out here before, i don't remember what the result was.
is the ecu displaying an error code?
Exeter
Mar 29, 2009 04:48 PM
