a ? about changind spark plugs
Old Feb 8, 2009 | 09:15 AM
joehill's Avatar
any one have advise for installing new spark plugs into a 3vze? i have a special tool to pull them out but that dosnt seem to help me put them back in.
Old Feb 8, 2009 | 09:17 AM
Jay351's Avatar
Usea peice of rubber hose just big enough to slip over the end of the spark plyug. Remember, these are aluminum heads so they are easier to mess up.
The plug should thread all the way in by hand, easily. What plugs are you using?
Old Feb 8, 2009 | 09:19 AM
desert-rat660's Avatar
sounds like the rubber insert is missing out of the socket.
Old Feb 8, 2009 | 09:28 AM
PCE91V64x4's Avatar
when I installed mine I put them in by hand and then tightened with a small 1/4" socket wrench (using adapters of course to the right socket size).
Old Feb 8, 2009 | 09:42 AM
joehill's Avatar
the main problem is getting them in to begin with. my hands are kinda big and I cant seem to maneuver very well even to sart them so i can then use a socket. right now im waiting for the temp to get up above freezing so doing this will be a bit more bearable.
Old Feb 8, 2009 | 10:55 AM
space-junk's Avatar
do what i did and grab a friend with smaller hands...
seriously tho, mine were a breeze to reach and i have pretty big hands too...
Old Feb 8, 2009 | 11:15 AM
joehill's Avatar
i got it. waiting till the temp got above 32 was a major help. made it so i could be a little more patient. just came back in to warm up and then im off to put in the new wires.
Old Feb 8, 2009 | 11:40 AM
iamsuperbleeder's Avatar
on that note, USE ANTI-SEIZE ON THE THREADS
Old Feb 8, 2009 | 12:30 PM
PCE91V64x4's Avatar
x2 on the anti-seize, and when I installed them by hand I put the plugs into the spark plug socket so I got a little more leverage and did not have to be as close to the block. Once you do it though the next time is easy.
Old Feb 8, 2009 | 08:55 PM
SMOD's Avatar
NGK all the way!
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
raptor510
Aug 19, 2015 02:15 PM
accuracy
Aug 4, 2015 08:05 PM
defrag4
Jul 31, 2015 10:50 AM
