Is a16 p compatible with a 18 p on the 1989 pickup ECU
Old Aug 31, 2019 | 08:10 PM
dcor23's Avatar
I have a 1989 Toyota pickup and am looking to replace a ECU is one with a 16p compatible with a 18p
Old Sep 1, 2019 | 03:30 PM
old87yota's Avatar
Welcome!
What ECU are you looking at? What vehicle did that ECU come out of?
Why are you replacing the ECU?
Old Sep 1, 2019 | 08:38 PM
dcor23's Avatar
70 Toyota pickup ECU compatibility
My check engine light is constantly on. Took it to the shop and they said that they hooked it up to do a diagnostic and it kept throwing inconsistent results. They said that it has got to be the ECU. Second opinion said ECU and/or mass flow sensor. I figured I’d start with the ECU first, since that’s the easiest to replace. Heee is a picture of my ECU and the one I found on eBay. The second PIN number is slightly off and wasn’t sure if it was compatible.
eBay ECU
ECU out of my truck
Old Sep 2, 2019 | 06:10 AM
old87yota's Avatar
Both the ECUs have the same part number so they should be the same.
I think what we are seeing for the eBay ECU second connector is that part of the label is rubbed off on the 8 making it look like a 6.
The second connector should have 18 pins for both yours and the eBay ECUs.
Old Sep 2, 2019 | 06:32 AM
scope103's Avatar
1. I think old87yota is correct about the number of pins. (while not conclusive, note how the 6's elsewhere on the ECU have a sloped top.)
2. Of all the possible causes of a CEL, a bad ECU is WAY down the list. I doubt that will fix anything. It's also NOT the mass flow sensor -- you don't have one (you have a VAF - volume flow sensor - different technology). So I would try to verify your first and second opinions. First, read the codes! If your shop "hooked it up to do a diagnostic and it kept throwing inconsistent results," it sounds like they didn't know how to read codes. Here's how to do it: http://www.4crawler.com/4x4/CheapTri...Codes/#Reading
Once you have the codes, you have a path to follow to diagnose your problem.
falcon4runner
Jan 3, 2015 11:30 AM
stevenf
Dec 19, 2013 03:36 PM
yant
Feb 19, 2011 03:12 AM
yoshi7182
Apr 13, 2008 04:52 PM
