95 4runner V6 3.0 3vze
Old Jun 6, 2012 | 01:10 PM
Team420's Avatar
pretty sure the c.s.i. wont matter above 50*F... thats for cold starts... unless it DOES spray above 50*, that would mean its defective, or the csi time switch is bad.
I still say, run a compression test! the tester can be had for $20 at napa, and could save you a lot of time searching for something that dosent exist...
Old Jun 6, 2012 | 01:18 PM
311runner's Avatar
Would compression cause the truck to start sometimes and not start at other times
Old Jun 6, 2012 | 01:25 PM
Team420's Avatar
If by sometimes you mean hard start when cold, but starts fine when warm, then yes...
but... if you mean, starts hard when cold 2day, but fine 2morrow even tho its the same ambient temp... then no...
Do you smell fuel when it cranks but wont start? and then when u get it started it blows a bit of black smoke? Gas in ur oil at all?
Old Jun 6, 2012 | 01:38 PM
311runner's Avatar
It seems like wen we take parts and clean them and put them back on the truck starts up normal put once u turn it off again it does the same thing. No black smoke never comes out of the exhaust
Old Jun 6, 2012 | 03:19 PM
  #25
Team420's Avatar
Even still... I'd run the compression test, then go from there.... It literally takes 15-20 min to do and at the very least, you will know if ur motor is healthy or not...
Old Jun 6, 2012 | 03:53 PM
  #26
311runner's Avatar
TEN-FOUR
Have to get those testers
Thanks
Old Sep 5, 2012 | 11:20 AM
  #27
henrypaz's Avatar
Originally Posted by scope103
Fuel, air, spark.
[I really don't recommend starting fluid. Ever. But if you insist and it runs for a few seconds, that tells you it is a fuel problem not an ignition problem.]
Scope--
I sure will second you on that! We had an old Ford mini-pickup ( Courier? ) that we totally destroyed the compression in by washing the oil off the cylinder walls trying to start it. My son did it, but I might have too, if I had'nt learned at his expense. It eventually would turn over like it had no plugs in it at all! Totally ruined that engine with starting fluid!
alexcarey
Oct 14, 2015 06:05 PM
Jdgarrison
Oct 1, 2015 05:22 PM
Jdgarrison
Oct 1, 2015 02:11 PM
icentropy
Sep 10, 2015 05:03 AM
seab1209
Sep 3, 2015 05:41 PM
