94 Toyota Pickup Starts Then Shuts off
Old Feb 11, 2013 | 04:15 AM
deerslayer126's Avatar
It runs for about 15 seconds then shuts right off. any ideas on what this could be. i just got the motor back from being rebuilt. put it in and started right up. The battery was being over charged so i put in a new altenator in now this happened. HELP!
Old Feb 11, 2013 | 04:34 AM
BamaYota1's Avatar
Check the afm, tps and cold start injector system. Something isn't hooked up or adjusted properly.
Old Feb 11, 2013 | 09:43 AM
scope103's Avatar
"Starts then shuts off" is the text-book symptom of a problem in the VAF-COR circuit. The key (at "START") turns the fuel pump on, and once air is pulled through the VAF it closes the COR (Circuit Opening Relay) to KEEP the fuel pump running.
It's trivial to diagnose. Jumper FP to B+ on the diagnostic connector to run the fuel pump. If it starts and runs then, you've found the problem.
DO NOT LEAVE THE JUMPER IN as a long term solution. You may die a horrible, fiery death.
Old Feb 11, 2013 | 10:37 AM
INFINITY's Avatar
unplug your cold start injector. if it does not start at all than your injectors are not firing. might be bad wires at the injector plugs.
6th Gear
19
Dec 10, 2019 07:31 AM
Weidle
Jan 21, 2019 05:39 AM
Crazychris1871
Jun 27, 2016 10:38 AM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
94hiluxZE
Jun 22, 2015 10:42 AM
