94 toyota 3.0 v6 running rough wont idle
Old Jan 24, 2014 | 08:42 AM
RJR's Avatar
RJR
Originally Posted by ksti
Did you do procedure for compression check per FSM?
120 psi is low min. is 142 psi with a 14 psi difference between cylinders.
Did you disconnect cold start injector and have WOT when testing each cylinder?
Depends on where he is. 125 is about right for 5000 feet elevation(Denver), goes down the higher you are.
Old Jan 24, 2014 | 09:45 PM
mcskittle's Avatar
Im in slc and no I didnt unplug csi and did not test at wot. Never heard of this before.
Old Jan 25, 2014 | 05:43 AM
RJR's Avatar
RJR
Salt Lake City is at about 5000 feet, so the 120 psi number is right on. Since all cylinders are the same, I'd say your compression is just fine. Wot or unplugging the CSI won't affect it by more than a couple of psi, and it's not exactly a precision test anyway.
Old Jan 25, 2014 | 07:39 AM
ksti's Avatar
So what your saying is the FSM is useless.
The engineers from Toyota just made this stuff up to fill the pages.
  #25
bone collector's Avatar
try this. pull the efi fuse and leave it out for about 2 minutes. replace it and start it up. see if the problem continues. I say this because I think you have fixed the problem when you replaced the afm and fixed the vacuum lines, but the computer just doesn't realize it yet. It is still trying to compensate for the bad parts. By pulling the efi fuse you will "reset" the computer instead of a limp mode. If it doesn't work you are only out 2 minutes.
Old Jan 25, 2014 | 09:58 PM
  #26
RJR's Avatar
RJR
No, not saying that at all. Just pointing out that , if he got 120 psi numbers at 5000 feet, his engine is healthy in that regard, and going back and doing it again with wot and the csi unplugged isn't going to tell him anything he doesn't already know, nor will it help him fix his problem. He might see numbers closer to 125-128 psi, but, so what?
If he wants to know more about the condition of his rings or valves, he needs to do an FAA style leakdown test. It's a much more sensitive test when done properly.
Old Jan 25, 2014 | 10:33 PM
  #27
mcskittle's Avatar
Will try the efi fus3 and get back to you guys. On a side note, I believe it has washed rings because it had quite a bit of gas in the oil when I just changed it.
Eggslinger
Jun 8, 2019 03:32 PM
montanatruck
Feb 26, 2017 07:07 AM
wafoogalla
Nov 2, 2016 11:02 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
markwink
Aug 18, 2015 12:38 PM
