94 runner didn't pass emissions need help
Old May 26, 2012 | 02:55 AM
skinny's Avatar
ok I'm new toy owner and my 94 didn't pass the ontario Canada e test.
here is the results
the driving test :
Hydro carbons limit is 52 my toy is 314
the CO limit is .29 my toy is .51
idle test results
Hydro carbons limit 200 my toy 1145
the tesst guy said the runner was missing . I'm a new owner and not really familure with toyota.
I bought the runner knowing it had few issues the intake boot was ripped so I replaced it with a so called performance k&n set up
I also replaced the plugs and wires.
I have a new cap and rotor ariving today to put on it
the burn on the plugs make it look like everything is the same across all 6. but upon runing it and removing wires from the cap it is looking like #3 did not make any difference on how it ran.
I checked all the plugs with ohm meter
when I found the possible issue on #3 I tried replacing the wire with an old one to see if that was it with out luck
well some time after 8:00 I will be able to get the cap and rotor so I will try that
any ideas would be great
Old May 26, 2012 | 05:00 AM
skinny's Avatar
i did the paper clip thing and got a flash of 2 then 6 I'm trying to find out what that means if anything
Old May 26, 2012 | 05:11 AM
skinny's Avatar
ok did some more reading saw something about grounds being bad on the motor could this cause a random missfire
I have had the plugs out and they didn't tell me that it was one cylinder over another
any help out there
Old May 26, 2012 | 08:57 AM
ksti's Avatar
First we need know what motor is in it. Put that info in your signature for the future. Second what brand plugs and wires? Lets start there and then go forward. Welcome to YT. P.S>Yes dirty or corroded grounds can cause problems.
Old May 26, 2012 | 10:41 AM
skinny's Avatar
It's a 3.0 v6
The wires and plugs I put in were ngk
The cap and rotor was nappa
Old May 26, 2012 | 10:56 AM
87 Deathtrap's Avatar
Have you checked timing yet? If not, I would start there, then check the o2 sensor.
https://www.yotatech.com/forums/f116...5-26-a-227295/
http://www.toyota-4runner.org/classi...sor-right.html
Old May 26, 2012 | 11:01 AM
ksti's Avatar
X2 on the o2 sensor
Old May 26, 2012 | 11:14 AM
skinny's Avatar
What is method of checking o2 sensor
Old May 26, 2012 | 11:52 AM
http://www.ttora.com/wiki/index.php/Oxygen_Sensor_Test
I typically just buy a new one and try it. If it doesn't make a difference, then I put the old one back in and hang on to the new one until I need it. Gonna need it eventually anyway. I may have some backwards logic though, so you may be better off following the link above.
Old May 26, 2012 | 12:14 PM
ChefYota4x4's Avatar
Found these quick with the "Code 26 on 3.0 4Runner".... Best wishes with your pesky gremlin, man!
https://www.yotatech.com/forums/f116...e-26-a-105541/
https://www.yotatech.com/forums/f116...5-26-a-114272/
http://www.toyotanation.com/forum/80...ere-start.html
http://www.4x4wire.com/forums/showfl...41&Main=975872
Old May 26, 2012 | 01:39 PM
skinny's Avatar
Well even it wasn't the o2 sensor it needs one now it broke off
Old May 26, 2012 | 01:56 PM
OOOhhhh... sorry man, it happens.
Go to partsgeek or www.sparkplugs.com and grab one for 1/4th the cost and call it a day...
http://www.partsgeek.com/catalog/199...en_sensor.html
http://sparkplugs.com/results_app.asp >>>> Part # 234-4052 or 234-4050 for the universal for 55$
Looks like prices are comparable; Have to double check the id # and shipping to be sure though. Still, it's what, 225$ at the Dealer? 55$ plus shipping seems a lil lower! lol.
Old May 26, 2012 | 02:00 PM
PS> The numbers I put in were for CA emissions.... Figured Canada was a lil strict like CA, but not sure, so you'd have to fish around from there.(Hope they even ship there, right? I've heard you guys having issues with that/getting parts sent to Canada???? )
Old May 26, 2012 | 03:27 PM
skinny's Avatar
are there any others that cross over
Old May 26, 2012 | 05:39 PM
ksti's Avatar
Did you check your timing jump TE1 and E1 and set at 10o BTDC.
Old May 27, 2012 | 05:21 AM
skinny's Avatar
hey what other than runing bad will happen if I drive with out O2 sensor
new one won't be here till tuesday and this is supose to be my daily ride
Old May 27, 2012 | 12:34 PM
Your mileage will SUCKEJIUWAIAH! lol. No, really, it will never STAY IN closed loop(not sure it will even GO INTO it).... so that means, "MORE FUEL" right? Shouldn't effect it as in "sputtering, etc."... In fact, it might fool you into thinking 'WOW, IT'S MUCH BETTER', just like when one pulls the TPS connector to see if it idles up.
Old May 28, 2012 | 10:57 AM
skinny's Avatar
Anyone used a o2 sensor from bluestreak
Old May 28, 2012 | 11:03 AM
runn4me's Avatar
Sorry to hear about your trials and tribulations with your toy...keep us posted on the final tally on your fixes to pass your emissions test.
Old May 28, 2012 | 11:10 AM
Skinny,
Can't get www.sparkplugs.com to ship one to ya at a reasonable enough price? Cuz I would stick with Denso, IMHO it's just not worth a few bucks savings if you can help it, ya know? Maybe Denso could tell you the 'specs' and then you can find out from one of their aftermarket sales co's which one would be, well, IDENTICAL? I would guess CA models would be similar... But I've heard Canada in some places isn't as strict as CA with emissions? No clue on that, but they MADE them for CANADA, .... there has to be an outlet somewhere, right????? lol. Your local parts store can get em, I bet... but they probably want like 180-200$?
