94 4runner underpowered anybody got any ideas??
Old Jul 29, 2008 | 03:15 PM
yotaman804's Avatar
Question 94 4runner underpowered anybody got any ideas??
My 4runner is really loosing a lot of power since i got it. It runs really rough when cold and sometimes even when its hot. It has no power. Any ideas what this is and how you fix it?
Thanks Zach
Old Jul 29, 2008 | 03:21 PM
abecedarian's Avatar
efi temp sensor, throttle position sensor, timing....
lots of things can cause the engine to run poorly.
maybe a little info on the engine / transmission would help...
...mileage, etc.
Old Jul 29, 2008 | 03:25 PM
yotaman804's Avatar
It is an auto trans 4x4 of course, it has 152,000,
ive heard putting a manual transmission in will give it some more power but the price to do that is super high.
Old Jul 29, 2008 | 03:26 PM
yotaman804's Avatar
oh and it is a v6 3vz in it
Old Jul 29, 2008 | 03:30 PM
Elton's Avatar
so you got a 3.slow and the auto well theirs part of the problem
Old Jul 29, 2008 | 04:30 PM
Matt16's Avatar
If you are losing power, try cleaning the intake (search). Seafoam works apparently.
Old Jul 29, 2008 | 04:32 PM
Matt16's Avatar
Possibilities:
Plugs
O2 sensor
Compression
Old Jul 29, 2008 | 04:37 PM
Jay351's Avatar
Im surprized nobody has mentioned GEARING!!! Looks like you are running good size meats. The automatic was undergeared from the factory. Those tires just made it worse.
Do a full tune up including: Oil change, plugs , wires, cap, rotor, air filter, o2 sensor and fuel filter...
Old Jul 29, 2008 | 04:43 PM
crolison's Avatar
3.4 swap
Old Jul 29, 2008 | 04:51 PM
yotaman804's Avatar
How should i change the gearing?
Old Jul 29, 2008 | 04:56 PM
ring and pinion gearsets, front and rear.
gives the driveshaft more mechanical advantage over the wheels.
not something you would want to tackle yourself.
listen to some of the advice here about tire sizes and gear ratios, then get a mechanic to do the work.
Old Jul 29, 2008 | 04:57 PM
yotaman804's Avatar
thanks does anybody recomend any sites wear i might be able to get some of these parts that are reliable but not to expensive?
Old Jul 29, 2008 | 05:01 PM
Jay351's Avatar
For ignition and misc parts:
www.sparkplugs.com
You should find out the stock gearing first. You can de-code the sticker on your drivers side door sill. Or do the spin-tire method..
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
nick9455649
Sep 11, 2015 05:10 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
