94 3.0 VZE 4 runner problems - need some help
Old Mar 24, 2009 | 11:44 AM
SEAIRESCUE's Avatar
Now that most vehicles are more electronic and less mechanical, good grounds and power connections are more important than ever. You just experienced one of those issues.
The ECU is attached to the chassis on a ground plane. I don't think Toyota relied on that attachment for a good ground. However, the three electrical connections to the ECU have many grounds. I suggest the mechanic put vasoline or electrical contact grease on the pins of all three connectors. Oxidized connections can cause the type of problems you have been suffering from on the runner. He may very well have lubed the pins and it started running just fine. Under hood ground points are critical. Battery ground is attached to engine block that is isolated with rubber mounts. The ground wire from the back of the block to the firewall is CRITICAL. I suggest you remove it, clean it and put it back on with vasoline under the attach points. And, I suggest whenever any electrical connector is removed, paint all those pins with vasoline. Works for me, including the battery!
JF9243176
Oct 8, 2017 04:21 AM
Alaskan91
Sep 21, 2015 04:39 AM
Alex Bessinger
Jun 28, 2015 10:05 AM
JF9243176
Jun 24, 2015 04:53 AM
nyk08trx
Jun 18, 2015 09:01 PM
