94' 22re 2wd exhaust leak.... remove pipe how?
Old Mar 10, 2012 | 10:12 PM
94Xtra22re's Avatar
Want to remove the leaking exhaust pipe between the exhaust manifold (stock) and the Cat to repair the crack at the weld. Anybody ever done this themselves? Want to take it out in one piece. I don't see how to get it off the truck. All bolts are off. It is loose, but either the torsion spring, cross member or somethings gotta be removed, or I just don't get it. Ideas
Old Mar 11, 2012 | 04:36 PM
94Xtra22re's Avatar
It was remove the cross-member. Remove 3 bolts, loosen 4th bolt and pivot the cross-member to the passenger side., Then remove the exhaust support from the bellhousing. Problem solved. Crack is welded and all is good for now.
Old Mar 12, 2012 | 07:25 PM
93liftedyoda's Avatar
it is hard to remove and takes time you just have to play with it and move it side to side
Colington
Mar 8, 2020 09:51 AM
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
colasurdo
Jul 16, 2015 11:32 AM
hexrain
Jul 12, 2015 01:13 PM
