93 yota 22re keeps stalling????
Old May 2, 2015 | 06:26 AM
shepsyota's Avatar
So i can hop in truck drive interstate speeds for about 20min. Get eng good and hot, stop to run in store come out start engine, it idles straight down and shuts off. Then if i dont feather gas pedal it will idle down and cut off while driving until i really get going. Cold starts seem to be fine, just having problems after a warmed up eng start. All new parts within last year, exhaust, o2 sensor, plugs, wires, air filter, fuel filter, timing chain, timing set at 5*. Seems to run fine, maybe lacking a little power. Problem really just started. Any help guys???
Old May 2, 2015 | 07:18 AM
scope103's Avatar
When you set the timing, did you jumper TE1 to E1? That forces base timing, which is what the 5° refers to.
Old May 2, 2015 | 08:59 AM
shepsyota's Avatar
Yes jumped terminals when set base timing to 5*
Old May 2, 2015 | 02:39 PM
shepsyota's Avatar
Any ideas?
Old May 2, 2015 | 04:18 PM
grumpin's Avatar
Several have a warm start issue. Read this one: https://www.yotatech.com/forums/f116...-issue-288051/
Old May 2, 2015 | 08:20 PM
Kiroshu's Avatar
Verify all vacuum hoses are in their correct locations.
Sounds like a temperature signal issue. Check coolant temp sensors.
Check air flow meter for a sticky air door..?
Air filter dirty..?
Idle speed incorrect..?
Throttle body dirty..?
Intake air leaks..?
Cold start injector fault..?
Air Bypass Valve(Idle Control) faulty and or dirty..?
Charecter1
Nov 6, 2023 10:08 AM
Sleaker
Aug 26, 2020 06:03 AM
_Nicco_
Aug 28, 2015 07:26 PM
ddg71
Jul 24, 2015 01:24 PM
Jnkml
Jul 6, 2015 01:20 PM
