93 Toyota truck won't start after long term storage
Old Apr 22, 2007 | 11:26 AM
airplanemech's Avatar
I have a 1993 Pickup, 22REC, automatic, that was parked for about 7 months ran perfect when parked. I charged the battery, the engine turns over but won't fire. Any ideas on where to start would be appreciated.
Old Apr 22, 2007 | 11:28 AM
Corbit's Avatar
Got Gas ?
Old Apr 22, 2007 | 11:33 AM
yes it has gas
Old Apr 22, 2007 | 11:45 AM
shoes138's Avatar
could it be that the gas is old?
Old Apr 22, 2007 | 11:50 AM
INFINITY's Avatar
bad gas i would say. drain tank, fuel rail, and return line.
Old Apr 22, 2007 | 11:56 AM
thook's Avatar
7 months? I doubt it.
Old Apr 22, 2007 | 12:20 PM
I wouldn't think 7 month old gas would be a problem but I do live in the south (Georgia) and moisture may have contaminated the gas. I am going to drain the tank, purge the lines, and go from there.
Old Apr 22, 2007 | 12:53 PM
mt_goat's Avatar
Got spark? Maybe some mice chewed up your wiring harness, it happened to my home AC unit last year.
Old Apr 22, 2007 | 12:54 PM
80W90's Avatar
find any mouse droppings around the truck?
possibly some meices chewed some wires.
check your cold start injector for fuel pressure.
check your plugs for spark.
open the air filter housing, make sure meices havent made a home in there, and then turn your ignition sw on, open the AFM, push the flop open with with your finger, and that will turn on the fuel pump.
make sure that is working, and that will also ensure gas is all the up the line to the cold start injector. now you can be sure fuel is supposed to be at that cold start injector.
Old Apr 22, 2007 | 01:24 PM
TNRabbit's Avatar
Check the big three:
1. Fuel
2. Air
3. Spark/Fire
Old Apr 22, 2007 | 03:57 PM
MMA_Alex's Avatar
i'd be surprised if the gas was bad enough that it wouldnt run, but i wouldnt expect it to run well with 7 month old gas unless you stabilized it. as stated above if the truck doesent start you need to check:
-fuel (thats air & gas)
-compression
-spark
with all three of those it should at least try to run
Old Apr 22, 2007 | 03:59 PM
4Crawler's Avatar
Fuel pump test jumper is an easy thing to try:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
My '85 fired right up after being down for about 11 months.
Old Apr 22, 2007 | 04:34 PM
shantz's Avatar
put some fuel stabilizer in there. pull your plugs , clean them and crank it
matrad
Aug 26, 2024 08:21 AM
zd92655
Mar 6, 2022 12:58 PM
Niameyrider
Jun 25, 2015 05:50 AM
newzingo
Jun 24, 2015 01:50 PM
Corey
Jun 10, 2002 04:23 AM
