93 3.0 Clutch replaced
Old Jan 21, 2019 | 02:20 PM
Suds1959's Avatar
93 just turned 200k miles. Jus replaced flywheel, pressure plate, clutch, throw out bearing, master and slave cylinder... Vacuum bleed, nothing but a full stream of fluid.. Clutch is still right on the floor, engages and works.... I know nothing to adjust but, still a lil rough going into gear..
I understand 1/16-1/8th inch of travel is major. I've adjusted the master cylinder plunger, just backed off from where the slave cylinder would not bleed..
any ideas?? could the slave cylinder arm be worn?? cupped enough to make the difference??
Thanks!
Old Jan 21, 2019 | 03:05 PM
scope103's Avatar
Read this first:
https://www.yotatech.com/forums/f116...fatigue-32667/
Old Jan 21, 2019 | 03:16 PM
Suds1959's Avatar
It travels good and smooth and nothing is broke or loose.. But, I will take a closer look to be sure...
Old Jan 23, 2019 | 05:37 PM
Suds1959's Avatar
Bracket looks like new!
Marcot1
Jul 29, 2008 09:27 AM
89yota_mudrunner
Jan 18, 2008 08:00 AM
TC4RNR
Oct 2, 2007 04:45 PM
Bob_98SR5
56
Dec 26, 2006 12:46 PM
Yoter
Oct 10, 2003 09:40 AM
