93 2wd Toyota not starting
Old Mar 31, 2013 | 05:01 AM
vanepps97355's Avatar
i have a 93 2wd toyota pickup i bought that has been sitting for awhile like years i have rebuild the motor put alot of new parts on it and its still not starting i replace the ecm the open circuit relay it has a new fuel put it has spark it has power to the fuel pump i ran a hard wire to the pump and got it to start but it would only run for a few seconds and die and then i found out the open circuit was y i didnt have power to the pump but now im stuck idk where to go now its like im not getting fuel but the fuel pump is working
Old Mar 31, 2013 | 05:16 AM
Porkchok's Avatar
It would help to know what motor you have and more about what you've replaced/rebuilt. The community here is very helpful and can help you get to the bottom of the issue if you can provide them with the right info, first. Good luck.
Old Mar 31, 2013 | 05:36 AM
sorry i forgot that its a 22re i have put a new head on it new bearings rv cam all new gaskets new starter, alternator, water pump, belt, new ignition, new fuel pump, ecu, open circuit relay, radiator, flywheel, clutch kit, new battery
Old Mar 31, 2013 | 11:38 AM
Co_94_PU's Avatar
http://personal.utulsa.edu/~nathan-b...fsm/index.html
http://personal.utulsa.edu/~nathan-b.../3troubles.pdf
Work your way thru the "Does not start" toubleshooting check lists.
Old Apr 1, 2013 | 08:54 AM
i dont have the time to do that i have 3 kids and i need to get this truck going cuz we have on car right now and we both work i have been having people give me rides and walking please can some one steer me in the way to go to what they think is wrong
Old Apr 1, 2013 | 09:30 AM
Porkchok's Avatar
You're going to have to do some troubleshooting on your own, buddy. Unfortunately we can't turn wrenches for you over the internet...
I'm just a newb myself so I can't offer too much advice but I do what I can... Those are links to the factory service manual for your exact truck. It has step-by-step guides for everything imagineable. Just browse through and see if you can find something you haven't checked/tweaked/replaced yet. Also, double check the procedures on the things you've already checked/tweaked/replaced to make sure you did them correctly.
Best of luck.
Old Apr 1, 2013 | 09:37 AM
Porkchok's Avatar
Oh and keep us all updated! We want to see you get this truck back on the road!
Cheers,
Zack
Old Apr 6, 2013 | 10:21 AM
well everything i replaced i did it to the specs i used my haynes book for everything i have replace and if it wasnt there i looked it up online
Old Apr 6, 2013 | 10:22 AM
and i will i want it back on the road to
Old Apr 6, 2013 | 11:34 AM
superex87's Avatar
The fuel pump should prime itself for 2 seconds when the key is turned on. The air flow meter tell it to turn on/off after that so make sure its in good working order.
Old Apr 9, 2013 | 04:07 PM
Well it fires up now but it only runs for like 10 secs I'm puzzled again
lledwod
Sep 6, 2016 07:33 AM
Bamripzit
Jul 19, 2015 01:17 PM
bigblue82
10
Jul 6, 2015 08:27 AM
DanStew
Jun 29, 2015 10:46 AM
dlotoy4runner
7
Jul 3, 2002 03:42 AM
