93 22re Intake manifold removal ??
Old Feb 5, 2018 | 06:20 AM
rancherman's Avatar
Originally Posted by Werm_Works
I'm trying to remove my intake manifold as well, got the top and bottom off but the wiring harness going down the tranny goes in between the lower manifold, is there some sort of connector on top I could remove instead of taking several connections down tranny including the 02 sensor?
6 yrs. ago, I just took a hacksaw, and removed the 'web' between the #2 and #3 runners. Took all of 15 seconds. Couple licks with a file and it looks fine. If you need to get that manifold completely out of the engine bay, all you do is lift the wiring up through that notch and lay it off towards the firewall. Probably have to disconnect the OP, Starter, Knock Sensor wire to gain enough slack.. but saves a pile of time on having to disconnect either the ecm or all the trans/ o2 wires and working with increasingly brittle plugs and wiring looms.
Otherwise, just lay the manifold off to the side and work with it with the wire still trapped.
Old Apr 1, 2018 | 12:41 PM
Ilovemytoyota's Avatar
Please have some advise
Originally Posted by Wile E. Toyote
be mindful of the "hidden bolt", there is a bolt on the lower intake that is recessed and hard to find. It is an alan head bolt near the front side of the intake under the fuel rail.
I recently helped my brother replace the 22r engine in my 95 toyota pickup. One of my fuel injectors is spewing gas from the fuel rail connection. I did some research, bough o rings and gaskets, grabbed my tools and got started. I removed all the necessary bolts, making sure to check (as a precaution) for the Alan bolt present below the thermostats on the 22re. I'm certain inhave a 22r. There is no alan/hex bolt on this engine. However, getting the upper manifold to separate from the lower is proving a nightmare. When it was installed, we used a new gasket and silicone rtv. Any advise for getting it loose without breaking something would b greatly appreciated. At the moment, it does not move at all without moving the rest of the engine. That's some good rtv. Lol. But seriously, I'd b externally greatly to get this done.
Doug4320
Mar 24, 2018 10:11 PM
steve miller
Oct 10, 2015 01:40 AM
Sep 4, 2015 09:27 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
87blyota
Jul 10, 2015 04:31 AM
