92 Toyota Pickup
Old Sep 4, 2010 | 07:51 AM
xxxtreme22r's Avatar
I don't see without changing the add shaft that the manual hubs will solve his problem
Old Sep 4, 2010 | 01:32 PM
MOTO193's Avatar
can i put a different diff in the front to eliminate the add. or would i have to do a axle swap.
Old Sep 4, 2010 | 01:40 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
I have a headache now...
Originally Posted by MOTO193
blew the lines out with an air compressor and one of my friends told me to just blow some air in the actuator. i guess it worked but now i cant even drive down the road.
but now cant even drive down the road without it binding up.
Can you punch your friend in the nose for me?
You know what I do in situations like this?
I research the subject. B/c I like to know WTH is going on under my own truck.
Here's a place to start...
http://home.4x4wire.com/erik/diffs/
And BTW, no ADD, no more shift on the fly...
However, fix your truck right, and add manual hubs and you can have both.
Unlock the hubs, and the shafts won't spin 100% of the time.
Lock your hubs and they'll be the same as when you had ADD drive flanges.
Old Sep 5, 2010 | 08:20 PM
MOTO193's Avatar
okay so if i read correctly i can swap out the old diff with a non add diff. What year toyotas come with the non add diff.
Old Sep 5, 2010 | 09:58 PM
  #25
NW-Yota's Avatar
pre-92...
someone correct me if im wrong
Old Sep 6, 2010 | 12:26 AM
  #26
ok, checkit...
Any 86-94 IFS Toyota, that did NOT come with ADD...
Old Sep 6, 2010 | 04:04 AM
  #27
I know for a fact at least the 92 model year had the manual hub as an option.
Old Sep 6, 2010 | 04:07 AM
  #28
92 TOY's Avatar
yup....my 92 has manual hubs
Old Oct 12, 2010 | 04:56 PM
  #29
MOTO193's Avatar
hey everyone, well took my toyota to a family mechanic and told him what was going on with my 4wd. He thinks someone regeared the rear end, and thats why it locks up on cement. i did the spin test and i got 43 drive shaft spins and 20 tire spins. thinking of regearing for 35" what would be the best to stock gear ratio. thanks and have a good day.
Old Jan 2, 2012 | 08:48 PM
  #30
MOTO193's Avatar
Hey everyone well got my four wheel drive working found out the ring gear had missing teeth where the pinion sat against the ring gear. bought some aisin hubs and a non add differential. Thanks for everyones advice. Happy New Year
Old Jan 3, 2012 | 01:13 PM
  #31
wildfire124's Avatar
vaccum leak
6th Gear
19
Dec 10, 2019 07:31 AM
Weidle
Jan 21, 2019 05:39 AM
Aleeex_u
Jun 5, 2016 06:52 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
zytra
Jun 24, 2015 08:14 AM
