anyone have a wiring diagram for 92 runner fuse box i have no power to the stop fuse! every thing else seems to work just fine is the fuse box just trash or am i missing something?
Yep it's trash, put up for sale at ¢10/lb..
How about you tell us what you gave already tested?
no brake lights checked fuse it was good, checked to see if I had 12v to the fuse socket no luck both sides dead! every thing else in the fuse box works without isses. so ran jumper to the brake switch, brake lights work! The only thing I can think of is fuse box issue cant seem to find digarm of fuse box any one know the line to check that feeds "stop" fuse I coud check and see if I have 12v t
There you go! Asking about a "brake" fuse while actually referencing the "stop" fuse is a why you got my offered $350 for your ride..
The stop fuse is fed directly from the distribution box 80amp circuit..
Identify the hot side of the fuse and work your way back to the 80amp fuse under the hood. The common practice is to find a mid point like the dash to engine harness junction (right hand kick panel) and start testing there.
You can test voltage or continuity, but you kind of already know you do not have continuity of voltage and need to just figure out why, isit a short to ground, a broken wire, or a loose connection.
