'92 22RE Strange Intake Noise
Old Apr 3, 2019 | 06:44 PM
camrycamper's Avatar
Video with air cleaner box open so you can hear. Been doing this for a month. 15% loss on all rpms. New plugs, cap, rotor
Check engine light flash shows no codes, Valve lash is in spec. New engnbldr.com head 2 years ago. Catalytic converter removed years ago. Carb cleaner test done on all intake. Airflow Sensor turns easily, not dragging. Could it be a potato stuck in my exhaust ?
Video;
Air delivery is stock (no cracks)
Valves, chain & guides are 2 years old and inspected with lash check
New chain tensioner hasn't been touched in 2 years - it's been running fine
Old Apr 3, 2019 | 07:07 PM
old87yota's Avatar
Is your air intake system stock?
Have you checked the air boot to the throttle body for cracks?
Old Apr 3, 2019 | 11:38 PM
ev13wt's Avatar
5 Year Member
Doesn't sound good at all. Lots of high frequency noises, metal on metal type. Oh boy.
Take off all accessories
Probably a valve?
Old Apr 4, 2019 | 05:50 AM
snippits's Avatar
Engine sounds like it is misfiring to me. The cause I don't know.
Old Apr 4, 2019 | 11:46 AM
ev13wt's Avatar
5 Year Member
Op has enough info in the op, but I got nothing.
Need more information please
Maybe a vid standing in front of the truck, reving it at the throttle body?
Test all sensors. A quick roger brown google search will get you there.
Recheck timing.
Old Apr 4, 2019 | 11:53 AM
ev13wt's Avatar
5 Year Member
I'll throw out chain tensioner. Did you replace?
The proper torque for it is something very low like "tighten by hand / loctite".
If it's too tight it gets stuck in the open position.
Is that the chain I hear?
cartercoulombe
Nov 27, 2022 04:49 AM
frankenfab
Mar 1, 2016 01:17 AM
Davebarbier
Nov 3, 2015 03:28 PM
BluYot
May 13, 2008 04:05 PM
joshik
Nov 27, 2002 10:20 PM
