91' FI PickUp rotates but won't start.
Old Jan 3, 2008 | 11:46 AM
Trinok's Avatar
Here's the story:
My truck was on E, the little red light was on and I didn't have time to put gas in it, so I parked her for the night. My driveway is on an incline. The next morning I go out to start her only to have it rotate, slowly, with no start. I immediately figured it was out of gas (incline not helping) and went and got 2 gallons. I put the gas in and it still only rotates, slowly. We roll it down the driveway and get it onto the street to see if that helps, nope.
Any ideas as to whats happening here? It was running fine the night before! Do you have to prime 91's when they run out of gas? I can hear the fuel pump working. Maybe the fuel filter is clogged? Fuel lines clogged?
Any advice and thoughts would be greatly appreciated guys!
Thanks,
John
Old Jan 3, 2008 | 12:00 PM
Albert.G's Avatar
is it cold where you live? if so.. gas might have frozen itself in the line.. OR your filter got dried up froze
Old Jan 3, 2008 | 12:15 PM
MMA_Alex's Avatar
might have sucked some crap up from the bottom of the tank too. after cranking it pull a spark plug and see if its wet with fuel. If not then its a fuel delivery problem (clog/freeze, etc) if it is it is probably just water/bad gas that got sucked up. If so you can try push starting it, which usually can blow all the crap out.
Old Jan 3, 2008 | 12:55 PM
drew303's Avatar
you said it rotates slowly? like waaahhhh waahhhhhh waaahhhh? The starter sound?
sure your battery isnt near dead?
Old Jan 3, 2008 | 02:05 PM
MMA_Alex's Avatar
thats true too. if the starter doesen't get enough power it can spin, but not enough to overcome the spring and spin the engine, or even spin the engine but not fast enough to start. probably worth trying to jump it or push start it, and see what happens.
Old Jan 3, 2008 | 02:09 PM
ChickenLover's Avatar
That was my first thought.. Jump that sumbitch and see what happens.
Old Jan 3, 2008 | 02:16 PM
jason191918's Avatar
X2 to all. If it is cold it's frozen, otherwise check battery.
Old Jan 3, 2008 | 04:32 PM
Jay351's Avatar
Start with the cheapest of the options. Jump the battery with another truck OR swap the battery with said truck.
The chev we have here had its battery go south, it wouldnt even take a jump/charge. What a pain that was.
Old Jan 3, 2008 | 04:50 PM
Trinok's Avatar
Well I charged the battery and that doesn't seem to be the problem. I guess something's frozen. Hmmm... I'm not really sure what to do.
Trinok's Avatar
BTW: it's auto not manny, no push starts for me! ;[
sandyota
Feb 4, 2021 11:16 AM
Doug4320
Mar 24, 2018 10:11 PM
Poncho0206
Jul 10, 2015 06:21 PM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
