91 4runner 3.0l
91 4runner 3.0l
I have an erratic idle problem. Sometimes it idle fine other time it won't idle at all. I bring it drive into the garage and it doesn't never seem to fail at home. I'm considering gasoline and matches as a cure unless I can get some help!
First place I would look is for a vacuum leak. With it running start looking around under the hood and listening for a vacuum sound or leak. Grab vacuum lines gently and twist or pull to see if the idle changes.
Jake
Jake
