91 4runner 3.0l
Old Dec 8, 2022 | 02:10 PM
pugsley73's Avatar
91 4runner 3.0l
I have an erratic idle problem. Sometimes it idle fine other time it won't idle at all. I bring it drive into the garage and it doesn't never seem to fail at home. I'm considering gasoline and matches as a cure unless I can get some help!
Old Dec 9, 2022 | 05:18 AM
Jakespeeds's Avatar
First place I would look is for a vacuum leak. With it running start looking around under the hood and listening for a vacuum sound or leak. Grab vacuum lines gently and twist or pull to see if the idle changes.
Jake
Old Dec 9, 2022 | 06:13 AM
rattlewagon's Avatar
What have you checked already? Manual or auto trans?
Any intake leaks? Any check engine codes? Runs/drives fine when its not idling?
Alaskan91
May 18, 2015 03:38 PM
dropped_dime98
Oct 11, 2008 08:08 AM
woodendude
Jul 23, 2008 10:08 AM
AxleIke
Apr 24, 2008 05:12 PM
ratedrookie
Feb 26, 2006 05:41 PM
