91 3vze major oil leak from the headgasket?
Old Apr 16, 2015 | 05:16 PM
mtrdrms's Avatar
So I'm bummed. I've had a small oil leak for a while and I thought it was valve cover gaskets but recently the leak got big. Like a steady drip after I turn off the truck for a few minutes. It amounts to maybe 1/4 cup. Not cool. So I just did the valve cover gaskets and the leak persists.
I think its the hg as it's coming from high on the drivers side. Anything else up there? I've never heard of just an oil leak from the hg. Truck runs great otherwise! Dammit. What should I do? Its a 1991 sr5.
Old Apr 16, 2015 | 06:57 PM
scope103's Avatar
Originally Posted by mtrdrms
... So I just did the valve cover gaskets and the leak persists.
I think its the hg as it's coming from high on the drivers side. ...
"High on the driver's side" DOES sound like a valve cover gasket, doesn't it? So the logical question is: Did you do the replacement correctly? Did you follow the manual? http://personal.utulsa.edu/~nathan-b...68cylinder.pdf (page 80)
If not, I can assure you that it WILL leak.
Old Apr 17, 2015 | 03:14 AM
mtrdrms's Avatar
Thanks a ton for the pdf. I did use fipg on the corners. The old gaskets were hard but not shot. This thing leaks like I left the gasket out!
Old Apr 17, 2015 | 04:16 AM
mtrdrms's Avatar
From searching pics online, I think there is an oil galley right at the back corner of the head/block. Just below the corner head bolt. It can't be too pressurized so the gasket must be completely gone there...
Old Apr 17, 2015 | 04:17 AM
mtrdrms's Avatar
What about the cam seal in the rear? Behind the valve cover?
Old Apr 17, 2015 | 08:45 AM
mtrdrms's Avatar
And it only leaks right after I shut it off. None while the engine is running. 3.4, here I come!
Eggslinger
Jun 8, 2019 03:32 PM
Ladythump
22
Nov 9, 2015 08:53 AM
jakebarrett
Jul 10, 2015 07:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
