91 22re in 88 22re truck?
Old Oct 23, 2016 | 01:37 PM
jzx81's Avatar
Hi there, my motor blew up. Can I put a 1991 22re into my 1988 EFI 22re truck?
Old Oct 23, 2016 | 02:08 PM
wyoming9's Avatar
Red face
Yes but use the engine Harness and injectors and ECU from the 88 engine
If you use the newer engine harness and sensors ECU your going to have quite a bit more wiring merging the two wiring harnesses
Old Oct 23, 2016 | 02:14 PM
jzx81's Avatar
Perfect, is that the only differences?
Old Oct 24, 2016 | 12:12 AM
Terrys87's Avatar
Block and heads are all the same. If it is a 2 wheel drive, you will need to swap oil pan and pickup tube. Use all the 88 motor components on your 91 block.
Old Oct 24, 2016 | 04:59 AM
jzx81's Avatar
Awesome, you guys ˟˟˟˟in' rock.
Thank you both.
