90's 4runner on to a 84 p/u?
I have been thinking of swaping a body from a mid 90's 4runner onto my 84 pickup extened cab. The body has seen better days inside and out.
Does anyone know if the dimenisions match closely? wheel wells, wheel width, ect.
Most may ask, why not just swap the axels under the 4runner? well i have a 302 with C-5 auto, marlin crawler box, ARB's front and rear. The list goes on and it would be pretty easy to do a body swap. wiring and body mounts are no problem.
Thanks in advance for your help.
You are gonna need to spend some time with a tape measure...wheel base seems different to me, but maybe with x cab wheel base you might be good but seems like you are going to run into some firewall issues with size of the v-8...engine pull in your future maybe.
anyway, here is a link that has online toyota factory service manuals where you should be able to find the frame specs you need
http://www.ncttora.com/fsm/index.html
and with a swap like this you should do a thread with lots of pictures, if it works it is gonna be pretty cool!
Flying91
45
Apr 11, 2024 04:39 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
BeMiceElf
Oct 10, 2015 09:40 PM
