90 toyota pickup 3.0 hesitating?
Old Mar 2, 2015 | 08:31 AM
creecher10's Avatar
After my dad and ï replaced the water pump on my yota it started hesitating under accelerating. Unfortunately with limited money we couldn't replace the timing belt. When ï get to about 2000 rpm it starts jerking and hesitating. What could it be?
Old Mar 4, 2015 | 09:09 AM
teaMJPx's Avatar
your timing may have skipped. check the tensioner for the timing belt right next to the water pump as it might have gotten loose and is not providing the force you need on the timing causing it to have issues... just a thought...
If this is the issue its a easy fix as you just have to take the cover off from the front of the cam gears and you should be able to access the tensioner.
Old Mar 4, 2015 | 07:54 PM
Swim's Avatar
X2 on the timing.
Old Mar 5, 2015 | 03:53 PM
Mauk's Avatar
Mine hesitates for a second but I think its because it only when i don't warm it up enough
Weidle
Jan 21, 2019 05:39 AM
Nathan_F
Aug 19, 2015 04:03 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
bprice0077
Jun 25, 2015 07:36 AM
nyk08trx
Jun 18, 2015 09:01 PM
