90 toyota pick up 2.4 rwd starts but shuts off in about 10 seconds
Old Jun 15, 2017 | 11:28 PM
kalidazez1's Avatar
jus rebuilt my front end on my 90 22re auto. the vehicle starts and sounds strong then after about five or ten seconds shuts off.. thats pretty much it, i am looking through the vacuum lines for cracks to repair. also currently looking my hose diagram for mistakes let me know if there ,is something you think i may be missing, thank you..
Old Jun 16, 2017 | 12:16 AM
muddpigg's Avatar
Sounds like only cold start injector is squirting; check ground the attaches to intake. Mount is rear pair of intake runners where the upper and lower intake is bolted together on under side of mounting flange.
Old Jun 16, 2017 | 05:08 AM
scope103's Avatar
If you searched for "starts but shuts off in 10 seconds" you would have gotten about 40 postings with your exact same problem. So, think about using Search.
Your problem is almost certainly in the VAF-COR circuit. It's the easiest thing on the whole truck to diagnose. Jumper FP to B+ on the diagnostic connector; that forces the fuel pump to run with key-on. Does it start and run okay now? You've found the location of the problem.
Old Jun 16, 2017 | 05:16 PM
thook's Avatar
mine did that after i did a complete rebuild. turned out to be the cold start injector wasn't sealed well on the plenum. took a smoke machine to find the leak
dntsdad
3.4 Swaps
59
Oct 15, 2021 04:17 AM
Ritzy4Runner
28
May 11, 2020 09:35 AM
Tilikum102602
93-98 T100s (Build-Up Section)
May 24, 2017 10:01 AM
welderdoug
Nov 11, 2012 01:44 PM
Blitzkrieg3002
Aug 10, 2012 09:34 AM
