90 3vz to a 95 3vz
Old Mar 12, 2009 | 10:03 AM
getrdunn's Avatar
90 3vz to a 95 3vz
Well I am swapping a 95 3vz which came from a 95 5spd 4x4 into my 90 2wd auto. I have been seeing some difference in the motor already but was wondering couple things. First, I want to know if the place where you mount the flex plate too is different from thetwo motors? I cant get the turque converter off of my 90 motor. I keep just stripping thebolt when I try. So could I just go buy flex plate for the 95 and will it all work with my tranny?
Old Mar 12, 2009 | 10:07 AM
DeathCougar's Avatar
90-95 all use the same flexplate.
In fact, toyota used the same flex plate from 1988 (V6) through 2002 in the 4Runners, T100, Pickups, and Tacomas
Old Mar 12, 2009 | 10:14 AM
getrdunn's Avatar
ok also a guy a trans shop told me that you have to change the shaft in the tranny because it is to long when you hook it up to a 4x4 motor. that sounds bogus to me but I want to check.
Old Mar 12, 2009 | 10:46 AM
Well lets be clear, you need to use the torque converter that came with the trans you are planning on using. The converter unbolts off the flexplate. If it doesn't come off, just cut the bolt heads, and extract the remains after you get it apart. Don't try to use the 4WD torque converter if you have a 2WD.
As for the shaft thing the trans shop said, as long as you use the 2WD torque converter in the 2WD trans, it will be the same. Again, same flex plate from 88 through 2002
Old Mar 12, 2009 | 11:26 AM
getrdunn's Avatar
ok thanks. I have another torque converter that I ordered for my tranny awhile ago so sounds like I am good. how do you suguest I cut the bolts that hold the torque to the flexplate
Old Mar 12, 2009 | 11:30 AM
Cut off wheel? Or you could drill the heads off. You could also cut the outer ring of the flywheel off, then use some vice grips to force the bolts off. They are held on with loc-tite from the factory, so they tend to be a PITA.
Old Mar 12, 2009 | 11:34 AM
getrdunn's Avatar
ok thanks for the help
matmattmatthew
10
Feb 9, 2021 04:15 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
D.B.T. 87 4x4
Jul 20, 2015 04:51 PM
