Drive Shaft Problem, clunk clunk (Video)
Old Mar 12, 2009 | 12:10 PM
chris1rb's Avatar
Ok, last week i finally fixed the motor and got the truck running really good and it past smog yesterday, but last night i pulled into a guess station and when i did i pushed the clutch in and coasted as i made a sharp right turn to park. As i did this i heard clunk clunk about 5 to 6 times, some what jolting the entire truck a little. also does it when i turn left but only when the clutch is in or the truck is out of gear.
Today i got under the truck and saw whats in the video. i guess the center support bearing is out? i can not repeat the noise to its intensity like when i was making the turn. also when its out of gear like in the first video lots of play twisting the drive shaft, when its in gear, not so much? shouldn't there be little to no play in or out of gear? greased them up yesterday thinking that would help but it did not, u can see the xtra grease in the video lol
Out Of Gear!!!
http://s226.photobucket.com/albums/d...t=100_0418.flv
In Gear
http://s226.photobucket.com/albums/d...t=100_0420.flv
Old Mar 12, 2009 | 12:27 PM
iamsuperbleeder's Avatar
lmao, yeah it deffinately shouldn't have that much play in OR out of gear
need a new carrier/center support bearing
Old Mar 12, 2009 | 12:41 PM
Matt16's Avatar
A little grease and it should be like new.
LOL
Old Mar 12, 2009 | 12:43 PM
chris1rb's Avatar
Do you mean the twisting of it? or just the woble and movement of the center bearing? Cause the twisting of it seems to be normal when its in gear, but it should not be moving that much in the center bearing if at all. Think it is just the center bearing? or possible something in the rear end or tranny?
Old Mar 12, 2009 | 12:48 PM
elblako91's Avatar
You need new u-joints and that center bearing piece(dont know the name of it) by the looks of it. Now would be a good time to replace all the ones on your yota.
Old Mar 12, 2009 | 12:50 PM
that center bearing is definately shot man
you'll have a little bit of twisting play while it's in gear, that's normal, cause if the gears meshed hard enough to make no play at all, your diff or trans would gernade in no time
and yes, as elblako suggested, U-joints wouldn't be a bead idea at the same time either
Old Mar 12, 2009 | 12:51 PM
chris1rb's Avatar
the yota has been sitting in a field for 2 years with a blown head gasket. finally fixed all that now i have this problem, seems like i am going to replace the whole truck by the time i am done
Old Mar 12, 2009 | 12:53 PM
lmao, see my thoughts about my truck and having to work on it almost every weeked, is that eventually I'll have a brand new truck
Old Mar 12, 2009 | 01:23 PM
chris1rb's Avatar
just hope this is it for awhile, hopefully the center support bearing is the only thing wrong,: knock on wood!!!
Old Mar 12, 2009 | 01:26 PM
if there's one thing I've learned, it's that when dealing with a 15 year old vehicle or older, expect something else to fail just as soon as you fix one thing...
and it'll be something completely unrelated to the last fix...
but it might be small; maybe a headlight or something will burn out, lol
but it never fails... for me anyway... maybe it's just my luck...
after my suspention rebuild last weekend, I'm waiting
Charecter1
Nov 6, 2023 10:08 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Avenged
Jul 9, 2015 07:55 AM
Jnkml
Jul 6, 2015 01:20 PM
wilbertd
Jul 6, 2015 07:39 AM
