90 22RE will fire over then cut right out...stumped
Old Jan 17, 2012 | 12:12 PM
quadrider32's Avatar
So I got a 90 22re extra cab
Truck has sat since august...started fine the other day but now wont stay running. Itll turn right over and start up but cut out after 3 seconds, after that it wont fire again until you wait 5- 10 minutes but yet again it will only stay running for maybe 3 seconds.
Anyone know what the problem could be...I appreciate any help
Old Jan 17, 2012 | 12:34 PM
Bassmastry101's Avatar
Have you checked your AFM? There is a link in my signature for the factory service manual that will help out when testing.
Old Jan 17, 2012 | 01:33 PM
Sensei's Avatar
Check fuel pressure. Check for plugged fuel filter. Check AFM as stated above. Not necessarily in any order but do all three.
Old Jan 17, 2012 | 04:07 PM
but how do I check for fuel pressure?...pretty sure I can locate and replace a fuel filter and that AFM link will help too.
Gonna try these tomorrow thanks for the help!
Old Jan 19, 2012 | 08:02 AM
Crack open the bolt on the cold start injector. You'll know if you got pressure.
Old Jan 19, 2012 | 09:10 AM
scope103's Avatar
Before you start wrenching, jump FP to B+ on the diagnostic connector. If the truck starts AND RUNS with the jumper, then you have a problem in the VAFM, COR circuit. (And not in the fuel pump or fuel filter).
Doug4320
Mar 24, 2018 10:11 PM
jake_v
Jul 22, 2015 03:17 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
Sandman
Jul 14, 2015 12:36 PM
Nickdigg
Jul 7, 2015 06:04 AM
