89 toyota pickup extra cab
Old Dec 20, 2012 | 03:32 PM
mgribb's Avatar
89 toyota pickup extra cab shutting off any advice
I have a 1989 Toyota Pickup extra cab. I have been having a problem with the truck just shutting off at different times. Doesn't matter what the temperature is or how long I have been driving. It just shuts off. Any advice would be appreciated. Thanks
Old Dec 20, 2012 | 04:29 PM
dropzone's Avatar
Fossilized
3.0 or 22R or 22re?
auto or stick?
Miles on truck?
Old Dec 20, 2012 | 05:22 PM
dakotawho's Avatar
Had this happen when my negative came off the battery a few times.
Old Dec 20, 2012 | 07:11 PM
ksti's Avatar
More info as stated above and have you done any kind of diagnostics yet?
Old Dec 20, 2012 | 07:15 PM
SPARKS89's Avatar
Is it turning off like you took the key out or is it dying off? If it's shutting off like it does when you take the key out I would start with the battery cables also. If it's dying out I'd start checking for vacuum leaks.
Old Dec 20, 2012 | 08:09 PM
90 yota's Avatar
Check the IACV, possibly some adjusting to get the RPM's a bit higher during idle, mine would die on me while slowing down and I adjusted it, problem fixed! it might not be the case with you as there are many reasons for a car to die, as well as more info is needed
Old Dec 21, 2012 | 01:00 PM
Chip N Sawbones's Avatar
Take the battery cables off and clean the battery posts with sandpaper until they're nice and shiny. Soak the cable terminals in water with a spoonful of baking soda to remove corrosion, and then sand the terminals down to bare metal so you've got a good clean connection with the battery. If you get battery acid on your hands, remember not to pick your nose or wipe your hands on your jeans.
Old Dec 21, 2012 | 10:12 PM
SPARKS89's Avatar
Make sure you pick up some dielectric grease to put on the connections too. It will help keep corrosion away which will ensure you keep a solid connection.
6th Gear
19
Dec 10, 2019 07:31 AM
Weidle
Jan 21, 2019 05:39 AM
5280jo
10
Jul 13, 2015 10:05 PM
PureTacoma_Tundra
PureTacoma_Tundra
Jun 29, 2015 09:45 AM
toy89yota
Jun 24, 2015 01:18 PM
