89 Pick up
Old Dec 27, 2021 | 02:28 PM
89pick_up's Avatar
89 Pick up
Hello
I bought a 89 pick up a few years ago
22r carb
4speed
so far it has
160,000 miles (12/2021)
the person who sold it to me lowered the truck
so far Ive only changed 2 parts
the coil pack (stopped working) and a PCV valve (cracked)
It is my Daily commuter to work
about 40ish miles mostly on the 405 between southbay and Westwood
I would like to fix the smoking issue which is leaving my spark plugs oily
and one day raise it to better handle the poorly maintained 405 commute
any recommendations, tips and tricks??
this is my first Toyota and first commuting car
Old Dec 27, 2021 | 02:53 PM
89pick_up's Avatar
this is how is sits
File Type: pdf
Old Dec 28, 2021 | 07:11 AM
JJ'89's Avatar
California? "Smoking issue"? How does it pass smog?
Old Dec 28, 2021 | 07:15 AM
89pick_up's Avatar
yes near Los Angeles
I have seen white smoke out of the muffler when I drive, park it and let it sit but soon after turn it back on
it wasn't that bad before
it has gotten worse
Old Dec 28, 2021 | 07:55 AM
Blackdoodle's Avatar
white smoke may be steam
Old Dec 28, 2021 | 07:58 AM
89pick_up's Avatar
with oily spark plugs
and it struggling to turn on
I doubt it is only steam
Old Dec 28, 2021 | 08:00 AM
Possibe...look at the oil on the dipstick. Hopefully not milky
Old Dec 28, 2021 | 08:01 AM
89pick_up's Avatar
the oil is not milky
compression test is good
with 160,000 miles I'm assuming its not a cracked piston
Old Dec 28, 2021 | 01:47 PM
2ToyGuy's Avatar
Probably not a cracked piston. Probably.
If I were to guess, which I am, I'd say head gasket, but that's just a guess on my part.
Have you checked the PCV for proper operation? Same for the EGR valve?
My guesses, is all.
I wish you the best of luck!
Pat☺
Old Dec 28, 2021 | 04:22 PM
89pick_up's Avatar
thanks
I bought a new head
gasket set, water pump and oil pump
also a catalytic and muffler
I hope with switching the head
can fix it
After that I want raise it and hopefully get it bigger tires for a smoother ride down the freeway
any suggestions on suspension upgrades ??
Old Feb 4, 2022 | 06:56 AM
89pick_up's Avatar
Bought a machined head, timing kit, oil+ water pump, gasket set, rocker arm assembly and head bolts
but now number #5 head bolt is broken..
Old Feb 4, 2022 | 06:59 AM
89pick_up's Avatar
bob9
Jul 15, 2013 05:08 PM
shiftless89
30
May 23, 2006 08:36 PM
