89 4runner auto trans fluid change
Old Oct 31, 2015 | 12:52 PM
8_9_runner's Avatar
Bought a 89 4runner with auto trans. Previous owner has no record of any tranny servicing. Is it safe to do a fluid change or does this trans react like a GM and "not leave the garage" as I've heard can happen?
Thanks for the replies.
Old Oct 31, 2015 | 04:54 PM
maco35's Avatar
Just use non synthetic Dexron ATF when servicing your trans. and don't worry these trannys are bullet proof.
Old Nov 1, 2015 | 03:53 AM
Truckwithoutaname's Avatar
Yes and be sure not to overfill it. The owner's manual is your friend.
Old Nov 2, 2015 | 05:24 AM
8_9_runner's Avatar
I forgot to mention the mileage in case it matters. Approx 190k. And yes, I love repair manuals!
Old Nov 2, 2015 | 09:23 AM
Janos01's Avatar
As long as the transmission is working normally (no excessive rough shifting, gears sliping) you should be fine. If there are issues but the transmission is working, I would not mess with it as changing the ATF when regular maintenance was not done could kill it.
diingodog
Jan 11, 2018 10:39 AM
Blizzard
23
Oct 3, 2005 07:31 AM
