89 22re pickup heating problems
Old Jan 3, 2012 | 04:54 AM
FattMaanLittleTruck's Avatar
you have a blown head gasket
someone has removed the thermostat to keep your engine from building too much boost in the cooling system and keeping the ponies under control
it's stoopid to just "take it to the radiator shop" cause some dood on yt said to check for blockages
I'm sure your radiator cap is fine too.
when I blew...i mean discovered my melted hg it had no symptoms other than lots of pressure in cooling system and blowing out anything i put into it. no water in oil, oil in water, smoke out exhuast, ect
go get a compression tester son!
Old Jan 3, 2012 | 11:44 AM
adsmith112379's Avatar
The mechanic said he's gotta pull the head. It it possible to put the head gasket backwards and it look right. I think its pushing exhaust into the water
Old Jan 3, 2012 | 11:47 AM
Bassmastry101's Avatar
The head gasket only goes on one way...
Old Jan 3, 2012 | 11:58 AM
abecedarian's Avatar
no, it will go on reversed. it is symmetrical, somewhat, in the long direction.
it will block oil and water passages if installed "up side down".
Old Jan 3, 2012 | 01:06 PM
  #25
wildfire124's Avatar
try flushing the system
Old Jan 3, 2012 | 01:07 PM
  #26
Head gasket is bad mechanic just called. Sending head off to be checked...wonder what that's gonna cost
Old Jan 3, 2012 | 01:48 PM
  #27
I'd guess around 800.
Old Jan 3, 2012 | 01:54 PM
  #28
Damn. This $3000 truck is starting to get expensive
Old Jan 3, 2012 | 02:45 PM
  #29
Ok, scratch my last post..It will only work one way.
Old Jan 3, 2012 | 08:30 PM
  #30
Buck87's Avatar
If it is pushing exhaust into the water I would expect to see steemy smoke out of the exhaust pipe.
Old Jan 4, 2012 | 03:31 PM
  #31
If it is pushing exhaust into the water then it would be forcing a lot of pressure into the cooling system, causing water to come out of the radiator. It would only steam out of the exhaust pipe if the water got into the cylinders.
Old Jan 4, 2012 | 05:38 PM
  #32
Buck87's Avatar
I stand corrected.
Old Nov 29, 2012 | 03:58 AM
  #33
89jburgess's Avatar
I've tried everything. Do you think it would have a blown head gasket? It started last night reving up and down when I press the brake.could the two problems be connected?
i had a problem with it doing the idle up and down same as you it was the idle control senser soon as replaced it quit.
Old Nov 29, 2012 | 07:30 PM
  #34
Buck87's Avatar
Pinch off the vacuum line to the brake booster. If that stops the idle issue then you probably have a vacuum leak in the brake booster.
Old Dec 3, 2012 | 07:12 AM
  #35
annoyingrob's Avatar
I had a cracked head that would pressurize the cooling system, but had zero coolant entering into the cylinders. No steam out the tailpipe.
To the original poster, you have it at the shop, they've taken it apart and are doing the head gasket, you might as well spend 200 bucks, buy a metal-backed timing chain kit, and a performance cam and have them install the two when putting it back together. It's already apart anyways, there won't be any additional labor.
Cesarl74
Apr 23, 2016 06:07 PM
85run
Jul 8, 2015 11:20 PM
bobbybouche
Jun 18, 2015 10:22 AM
Old Red 94
Jun 16, 2015 08:32 PM
BTOWN4RUNNER
12
Aug 15, 2002 05:58 PM
