89 22re to 94 truck swap help
Old Dec 7, 2008 | 10:57 AM
blksta's Avatar
Hi, sorry if this has been asked a 1000 times i tried searching and found nothing. I picked up a 22re out of a 89 truck, I thought it was a direct swap into my 94 but i thought wrong. Almost every electrical connection is different. Can I just swap the intake manifold from my 94 onto the 89 motor along with the other sensors? It looks like my 94 has a lot more vacume lines that attach to the valve cover so I assume I'll have to change that too? Thanks
Old Dec 7, 2008 | 12:51 PM
Ezrider_92356's Avatar
as far as i know everything should swap over without a problem
Old Dec 8, 2008 | 03:11 PM
blksta's Avatar
everything seems the same straight down to the sensors, they just have the older "metal clip" style connectors instead of regular push and pull clips
Old Dec 9, 2008 | 06:24 AM
rdlsz24's Avatar
I did almost the opposite swap as you did. I swapped a '94 22RE into an '88 truck. I used used the wiring harness and injectors from the '88, and swapped over anything else where connections, etc were different.
Rob
Yont283
Sep 23, 2022 08:06 PM
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
puffin04
Jul 10, 2015 09:17 PM
noahstancik
Jul 10, 2015 11:18 AM
streetuner15
Jun 18, 2015 10:59 PM
