88' truck having some issues
Old Oct 5, 2008 | 12:09 PM
ohyeahcrx's Avatar
Alright, so im going to try all the possible problems listed above. And I also found out that a knock sensor never really goes bad, it just gets corroded, and you have to change the pigtail.
I am not able to try it now because i took the radiator (to get it rotted and cleaned out) and thermostat (to replace it) out so until I put that all back together ill just have to wait. But if anyone has any more ideas feel free to post.
Thanks for everyones help so far :thumbsup:
Old Oct 8, 2008 | 10:20 PM
ohyeahcrx's Avatar
Ok so I thought i would be able to fix my over heating problem, but i was wrong. i flushed the radiator a bunch, new thermostat and put it all back together. Its still overheating, and boiling....any ideas?
Old Oct 8, 2008 | 11:07 PM
sh0kk86's Avatar
hows the water look? oil?
Old Oct 8, 2008 | 11:14 PM
ohyeahcrx's Avatar
Do you mean like the water in the radiator? Cause it just gets boiled out everytime i fill it up/
Old Oct 8, 2008 | 11:28 PM
  #25
Jay351's Avatar
Yes, is there anything floating in the water?
Get a new radiator.
Old Oct 9, 2008 | 12:52 AM
  #26
sh0kk86's Avatar
well if the previous owner only put water in, i bet hte inside of your block is rusted out. unless you flushed your entire engine/coolant system, you still have that stuff floating around.
with that said. my engine went around along time like that, and at 185k it now loooks like this http://img.photobucket.com/albums/v1...t/7c0bb291.jpg
Old Oct 9, 2008 | 02:16 PM
  #27
ohyeahcrx's Avatar
Wow...i hope thats not what mine looks like....But i have no way of knowing how long she went with only putting water in it...what did you do about your rusty engine?
Old Oct 18, 2008 | 02:15 PM
  #28
ohyeahcrx's Avatar
Ok so to everyone who was wondering what was wrong with my truck:
I took it to a shop, and they found water in the oil, they said it looked like chocolate milk. But the compression was fine so it wasnt a blown head gasket. I guess on the 22re engines, the timing cover can wear a hole in it. So that explains why its overheating and why its running like crap.
So i gotta fix that :/
Old Oct 18, 2008 | 03:10 PM
  #29
black diamond's Avatar
the hole in the timing cover will put coolant in crankcase, wouldn't say it would effect engine running condition or ovrerheat until low level. the timing cover is prob junk, but you may have another issue. just an opinion.
Old Oct 18, 2008 | 09:07 PM
  #30
ohyeahcrx's Avatar
Yeah well wont all the coolant going in to the crankcase leave no coolant running through the cooling system? Which leads to overheating?
And its throwing the knock sensor and TPS code so ill still check those aswell.
Old Oct 20, 2008 | 09:44 AM
  #31
ohyeahcrx's Avatar
Anyone have any comments or anything, would be greatly appreciated
Alex Bessinger
Jun 28, 2015 10:05 AM
WI Girl
Jun 25, 2015 03:45 AM
saphirekosmos
Jun 22, 2015 10:26 AM
slider417
Jun 22, 2015 10:18 AM
bobbybouche
Jun 18, 2015 10:22 AM
