88 p/u, trying to swap fuel pump by lifting bed, one bed nut just spins?
Old May 12, 2019 | 05:31 PM
uraceulose's Avatar
I’ve got all 4 on driver side loose. 3/4 of passenger side came right off. The furthest forward of the bed mounting bolts was double nutted with 19 mm nuts. The second one is just spinning and I can’t get enough pressure on the carriage type bolt with my finger to allow the nut to loosen..not much rust but enough hunk to where I can’t get it loose. Any ideas besides dropping the tank or cutting a hole in the bed to get at it from the top??
thanks so much
Donnie
Old May 12, 2019 | 07:08 PM
richiethomson's Avatar
im just going to be the first to say it. Drop the tank.
if i remember correctly its only 6 bolts, the skid comes off with the tank, remove a few hoses, undoo the whole fuel nozzle, it all drops easily.
I dropped my tank with 2 galloons remaining with only a regular jack.
re installing it is even easier then dropping it.
Old May 12, 2019 | 07:10 PM
uraceulose's Avatar
I probably will end up just doing that, already have everything ready to lift the bed other than ONE nut so I figured I’d ask
Old May 13, 2019 | 02:37 PM
gyates93's Avatar
Cut it off and replace the bolt!
Old May 14, 2019 | 12:36 PM
ev13wt's Avatar
5 Year Member
Cut.
5char
ev13wt
Mar 18, 2019 03:14 AM
BURR2OF4
Apr 15, 2013 04:52 PM
Kyle95sr5
10
Nov 14, 2008 12:01 AM
EDGE
14
Apr 18, 2004 05:26 PM
