88 Chinook Camper Conversion, Brake Question
Old Jun 19, 2025 | 08:54 AM
Rusker's Avatar
Exclamation 88 Chinook Camper Conversion, Brake Question
I need to upgrade the front brakes after swapping the Chinook Camper on my 88.
1988 Chinook Camper
I've read a few different posts about the V6 caliper upgrade and I've spoken to a few shops. I'm a little confused on the information I was given. Here is my parts list
(2) V6 Calipers (early 90s toyota pickup)
1" FJ80 Brake Master
Rotors ( 88 4x4, rock auto)
V6 Caliper brake pads (rock auto)
New SS brake lines
I thought I could also upgrade the rotors but I was told that is only an option for solid axle trucks, not IFS.
Old Jun 19, 2025 | 09:15 AM
coryc85's Avatar
First of all, we need more pics of that Chinook. I don't know if this is 100% the correct answer to your question, but I believe the older trucks with solid front axles happened to also have solid rotors. The later trucks with IFS came with vented rotors, which I guess are an upgrade, so you've already got the right rotors.
Old Jun 19, 2025 | 10:54 AM
Rusker's Avatar
1988 toyota chinook conversion 4x4
Perfect. So as long as I'm buying the 88 rotors for my truck it should be compatible with the V6 IFS calipers everyone upgrades to?
Here is the current state of the build. Trying to dial in everything before I start the process of thinking about having it repainted.
Old Jun 19, 2025 | 10:58 AM
Hugefatchick's Avatar
you are correct in keeping rotors, sick truck! Thought I’d share the pos motorhome I built years back
Old Jun 19, 2025 | 11:05 AM
Rusker's Avatar
Wow! I've always thought a 4x4 sunrader would be a great platform to build.
Old Jun 19, 2025 | 11:42 AM
sunrader was neat, my honest opinion the chinooks a way better platform, more room= more crap, more crap in an underpowered vehicle with a lift is misery
Old Jun 19, 2025 | 12:08 PM
coryc85's Avatar
Both of those campers are very cool, you've got me browsing craigslist now!
Old Jun 19, 2025 | 01:35 PM
millball's Avatar
Er.... The later V6 calipers and the rotors they are paired to are not the same as your '88's
In late '92 they changed the rotor thickness, so those rotors and calipers are a bit heavier duty than the earlier ones are.
The '93 to '95 V6 IFS front brake parts are the best for this upgrade.
I had to trim the brake backing tin on my '87 4Runner, but no biggie.
I was happy keeping the original type master cyl.
Old Jun 19, 2025 | 09:20 PM
aztoyman's Avatar
Milball is correct...as usual. The V6 calipers and rotors are an easy bolt on improvement.
Way back I went even bigger with T100 calipers and rotors. I posted it on Marlin Crawler forum. I'll see if I can find it. It made a big difference but even more noticeable was a dual diaphragm booster from a 2nd gen 4Runner. (Maybe V6 pickups too) This was all on my 88 standard cab 22RE 4x4 IFS pickup at the time. I'll see if I can dig up the links.
Old Jun 19, 2025 | 09:22 PM
aztoyman's Avatar
Here's the T100 thread. https://board.marlincrawler.com/index.php?topic=77523.0
Old Jun 19, 2025 | 09:31 PM
aztoyman's Avatar
The brake booster was from a early 90's 4Runner or pickup with the 3.0 V6. A bolt in deal. I used the same master cylinder which I believe is the same as the one Millball mentioned. Going from a single diaphragm booster to the dual was night and day difference.
The T100 calipers cleared the chrome modular 15" steel wheels I had back then. Not sure about the wheels you're running. Something you need to check whenever going to larger brakes.
Old Jun 20, 2025 | 07:26 AM
Rusker's Avatar
So I just need to buy 93-95 V6 calipers, and rotors and everything should fit? I'm assuming I could just buy all of this from RockAuto
Old Jun 20, 2025 | 07:28 AM
Rusker's Avatar
How much bigger are the T100 calipers?
Old Jun 20, 2025 | 07:30 AM
Rusker's Avatar
Thank you! Are these similar to the ealry Tundra calipers? I did the 1st gen Tundra calipers and rotors on my Tacoma.
Old Jun 20, 2025 | 07:31 AM
Rusker's Avatar
My biggest concern is clearing the new wheels I just bought. So I'm a little worried about going bigger than the V6 calipers everyone seems to upgrade to.
Old Jun 20, 2025 | 10:51 AM
aztoyman's Avatar
Yeah, bigger brakes gotta fit your wheels for sure. The ones millball referred you to should fit and are still an improvement over what you had originally. Rock Auto is a really good reference for the specs of the parts. They do list the diameters and thickness of the rotors and the caliper piston size.
I buy from Rock Auto if they are the best price to my door. I google the part number and often find the best price is at Walmart and even Home Depot now. Even OEM parts. Surprised me. Good deal for me because of the free shipping and the veterans discount.
The dual diaphragm booster is worth it if you just have the single. A noticeable improvement in pedal effort.
Sorry to overwhelm you with so many options. Stick to what fits your wheels and make sure the calipers, pads and rotors are from the same truck. The 93-95 V6 IFS as millball recommended. You can verify the specs on Rock Auto and even compare to other years.
Good luck with your project!
Old Jun 20, 2025 | 11:31 AM
Rusker's Avatar
So the best option is to choose a model year of the V6 pickup and buy the calipers, rotors, brake booster and brake master? I may just buy all of it from RA just to keep it simple
Old Jun 20, 2025 | 11:33 AM
millball's Avatar
I'm pretty sure that if you read aztoymans T100 thread carefully, you'll find that the T100 calipers and rotors and the '93-'95 4Runner V6 calipers and rotors are identical.
A check on Rockauto for corresponding parts numbers confirms this.
I did not check booster and brake master numbers.
Old Jun 20, 2025 | 10:09 PM
aztoyman's Avatar
I got the MC and booster from a guy parting out a 90's 3.0 4Runner and I think it was earlier than the 94 model year. I JUST recently replaced that MC. Yep, finally died. I put in an ADVICS (Denso) BMT-051 from Rock Auto. The 94 and 95 4Runner take the BMT-081. The only thing I see different is the level sensor is in the reservoir vs in the cap. The bore is the same at 1". IDK if the rest is the same.
The 93 and earlier V6 4runner booster and master fit my 88 standard cab. I'm sure the rotors and calipers would have too.
I have two sets of those MC and boosters from back then. The other was from a 93 Extra Cab my son bought. Just the cab actually for a project. Same part numbers for the MC and booster.
I just removed the T100 calipers and rotors and I have huge 2017 4Runner calipers and rotors now. They are under steel Raceline 17" beadlocks. NO WAY would they fit smaller wheels.
Old Jun 21, 2025 | 10:30 AM
osv's Avatar
osv
here are the bigger 1" bore rear drum slave cylinders that i'm running with the fj80 master cylinder:
Amazon Amazon
looks like the are only $10 each at rockauto, they list the specific dimensions: https://www.rockauto.com/en/parts/ac...+cylinder,1952
