88/89 Speed Sensor - # pules?
Old May 1, 2007 | 09:49 AM
ewong's Avatar
OK
The 88/89 era (Gen1 4Runner) had a speed sensor.
But it was built into the instrument cluster, not attached to the xfer case as the later ones were.
Im thinking of going to an aftermarket speedo and the Marlin part is just the ticket.
http://board.marlincrawler.com/index.php?topic=30862.0
The FSM for my 4Runner specs the SPD signal as one pulse per 40cm (man is that accurate or what?)
Assuming an OEM tire is 225/75R15 and converting I get
(22.5cm x 0.75 aspect x 2 sidewalls ) + (15in x 2.54cm/in ) = 71.85cm
using pi x d for tie circumference = ~ 225 cm diameter
diving by 40cm I get 5.6 pulse per rev...
Anyone know if that is going to cause problems for the EFI if I take out the cluster and replace it with the Marlin Speedo?
montanatruck
Feb 26, 2017 07:07 AM
ty1er
Aug 1, 2015 11:53 PM
Feadship
Aug 1, 2015 12:18 AM
wilbertd
Jul 6, 2015 07:39 AM
karbin
Jul 5, 2015 11:37 PM
